Oil Leaking from AC Compressor?
Old Apr 2, 2009 | 10:16 PM
Dafried's Avatar
Enthusiastic Newbie
Hi All,
Noticed small amount of clear oil (4 inch square) under car. Checked the dipstick, since I use Mobil 1 and no problem.
Friend suggested that my AC compressor could be leaking oil. AC seems to be working ok, but it won't soon with the AZ heat.
I have 94,000 miles on my '05 - any ideas / fixes?
Thanks in advance,
Dafried
Old Apr 3, 2009 | 08:21 AM
Turbonut's Avatar
Take a look at the power steering. You won't see any oil dripping from the compressor. If you did, the compressor would be a gonner and the A/C wouldn't operate.
Get the car up in the air and take a look directly above the area where the oil spot was located.
Old Apr 3, 2009 | 01:55 PM
Majofo's Avatar
Need more info.. like location in reference to engine. PICS!
Was it really oil / lubricant? color? smell?
Get under the car and look for leaks / signs of leak under the case and tranny case. Turbonut is right.. if the AC compressor leaked it would be shot.
Old Apr 6, 2009 | 12:22 AM
Nick337's Avatar
refrigerant oil normally sticks to something like a hose or something on the car itself, I have never seen it get all the way to the ground
Old Apr 8, 2009 | 07:44 PM
daniel_htech's Avatar
5th Gear
sure its oil and not just water from the evaporator drain for the ac system?
Mike734
Dec 10, 2021 01:25 PM
IBankMouse
Jun 13, 2020 12:53 PM
spudweb
May 22, 2016 02:39 PM
Avenger411
Oct 11, 2015 03:53 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
