Clicking noise when turning
Old Mar 24, 2009 | 10:15 AM
6spdtl-s's Avatar
Nismo TL yo!
My TL will sometime make a clicking noise when it is down in the 30 deg. F range while the car is still cold. Once the car warms up the noise seems to go away. I think its the CV joint, but can anyone chime in here with some experience? is it anything I should be concerned with or that I should replace? Thanks!
Old Mar 24, 2009 | 10:39 AM
Turbonut's Avatar
Classic symptom of worn outer CV joint. When turned, the balls move around inside their worn cage and thus the clicking sound. They don't usually fail to the point of the vehicle being not driveable, but will continue to get worse with time and mileage.
Old Mar 24, 2009 | 11:00 AM
MistahSleepy's Avatar
Hey I noticed this the other night, when I made left turns there would be a light clicking noise that happened intermittently the entire drive home. Since then I have not heard the noise again.
My car only has approx. 4600 miles on it though...
Should I be concerned? I know if I tell the dealer about it he's just going to say he can't reproduce the problem..
Old Mar 24, 2009 | 12:14 PM
Turbonut's Avatar
Try it in reverse with the wheels turned, it should be worse if it's a CV joint. Usually the joints are good for 100K plus, but there other items eg brakes that can casue that sound.
When it happens, just apply the brakes slightly to see if it stops.
Old Mar 24, 2009 | 12:21 PM
Sal's Type S's Avatar
I'm with Turbonut..
Old Mar 24, 2009 | 01:13 PM
6spdtl-s's Avatar
Nismo TL yo!
cars only got 50k on it I guess I'll let it be until it starts making noises when the car warms up
Old Mar 24, 2009 | 02:06 PM
myron's Avatar
I have the same problem and I started noticing it when teh temp was -40 celsius. Now that its warmer I can't hear it but I will get it looked at when I get my suspension installed in a week or 2. I will post in here what my mechanic says if noone else does
Old Mar 25, 2009 | 12:03 AM
Majofo's Avatar
Cold temps (0 degrees) cause the boot grease to stiffen which could be the reason for the clicking. Once the boot grease raises temp to operational spec the clicking will go away. From my research, most boot grease is rated for high temps.. but not low temps. If you notice this all the time at full lock turns either left / right going forward and reverse.. you have the symptoms of a failing cv joint.. check the boot for tears / cracks / leaking grease. It may also be the hub bearings but haven't heard about too many hub bearing failures for the 3G TL.
Old Mar 25, 2009 | 12:06 AM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
It sounds to me like CV boot/joints, as well.
Old Mar 25, 2009 | 09:51 AM
myron's Avatar
well if it is CV boot/joints, how expensive is this to fix. Parts and how much labor is involved in this?
Old Apr 7, 2009 | 08:42 PM
daracer18's Avatar
i got the same problem with my 04 tl with 60k.. it only does it when cold, after driving it for a while u cant hear it.. Sounds like a bad axle but wat i dont understand is that it stops when warm..
Old Apr 8, 2009 | 03:35 PM
NJcriscuolo's Avatar
yeah
i had the same problem in my 2005 tl brought it to the dealer and he told me my axle boot ripped and the warranty coverd it or else it would have been 700 incidentally does anyone know where i can get a black trim for the interior of the car to replace the wood style trim?
Old Apr 8, 2009 | 03:41 PM
Majofo's Avatar
Think water..
Room temp - liquid..
0 degrees C - ICE..
As the grease warms up it softens.. remember it's meant for high temp apps not low temp.
Old Apr 8, 2009 | 03:43 PM
Majofo's Avatar
You mean the black wood trim? or just black trim? Have you tried a sharpie? lol.. try searching the threads or posting a new thread but in the right forum topic.
Old Apr 8, 2009 | 03:49 PM
Red face
I want to but (dont Laugh at me) im new to the site and dont know how to post a new thread
https://acurazine.com/forums/images/smilies/tomato.gif
and i just want the black not the black wood
Old Apr 8, 2009 | 04:21 PM
Majofo's Avatar
I haven't seen a pure black trim.. I know of the black wood kit and the dark carbon fiber kit.. You might want to to think of vinyl overlay. http://www.decalfx.com/vinyl_sheets.html
Majofo's Avatar
fixed.
btw.. go to the top off a forum topic and click on the new thread button.. but if you don't want to get a dozen replies telling you to search.. you should probably use google.. it's your friend.
Old Apr 8, 2009 | 05:17 PM
spicynoodle116's Avatar
Newb
I "think" I have the same problem. My engine makes a really loud sound, kind of like an electric car when I start it up after a long time in parked, regardless if its cold or not. It goes away though after 5-10 minutes of driving.
Old Apr 8, 2009 | 10:14 PM
Majofo's Avatar
That's not your CV joints / driveshafts.. that's more than likely your power steering pump. You probably have the same problem that many like myself have encountered. The inlet to the power steering pump is letting in air. Solution.. new o-ring ($0.60).. 10 sheets of shop towels, 10mm ratchet & 5 mins.. done deal. The power steering only seeps in air in cold temps.
A decent way to check is to start it up in the morning when it's below 50F.. If it's making noise near the drive belt.. open the top of the power steering fluid reservoir and check to see if air bubbles are forming at the top.. you have found your problem.
The hardened CV boot grease / bad CV joint symptom occurs only on full lock turns at low speeds is when you'll notice it.. it's not loud.. just a creaking / clicking..
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
gemz_acura
4G TL Problems & Fixes
15
Sep 26, 2015 06:12 PM
PortlandRL
Sep 14, 2015 12:01 PM
aces2412
3G MDX (2014-2020)
Sep 7, 2015 08:40 PM
