Oil leak
Oil leak
Noticed that my oil pan is covered with what seems like motor oil. I've pretty much ruled out that it is the bolt and washer as even the the top of the pan is wet. It seems like the oil is leaking from the passenger side. What could be the culprit? As far as I know our cars don't have a rubber oil pan gasket but instead use Honda bond or something like that correct? Can that leak? How can one diagnose if it is the oil pump? I know that can be a issue for these cars. If it is something like the oil pump gasket would using a high mileage oil that conditions seals help? Car has about 150k miles.
could be oil pump gasket. and the best remedy would be fixing the problem by replacing the gasket.
if you try to use a thicker oil or a high mileage oil, you're NOT fixing the problem. it MIGHT delay the leak, but the leak will always be there. and that's not how you fix things.
E39 (01-18-2018)
My car developed an oil pump leak which produced a thin layer of oil on the pan and a slight burn smell when running but stopped.
Acura dealership wanted $1600 to fix (and $95 to diagnose the problem, after they told me what the problem was...I said no thanks). Since the leak only produces a very small amount of oil loss between changes (no oil drips onto my garage floor and I never have to add any oil between changes), I decided to let it be. That was almost 4 years ago and over 100,000 miles. So go ahead and find the source, but if it is only a small amount of oil and not a threat to damage the engine, just leave it along and save some significant $$$.
The following 2 users liked this post by quantum7:
E39 (01-18-2018),
justnspace (01-15-2018)
How does one go about diagnosing if its the oil pump or not? Don't things have to come off?
Do our pans ever leak because of Honda bond wearing out?
Could it be the oil filter gasket even if the oil filter and housing are dry? No right?
My leak seems pretty significant right now as the whole area is wet including part of the subfram. Is it true that with the J series engine synthetic oil can produce leaks? I've heard with J series engines conventional should be used? Any validity to this? It's weird because I put in red line 5w30 like 500 miles ago and now this leak is new. Probably coincidental. But what's also weird is I use to have a slight rear main seal sweating that once I put redline soon became bone dry.
E39 (01-18-2018)
Latent car nut
I'm not sure where you got that, but you have our permission to tell whom ever said such a thing they're full of crap. There have been literally millions of J-Series engines run for, I don't know, billions of miles on synthetic oil without a single leak. I have just two of them, a J30 and a J32; both have been run exclusively with synthetic oil since I purchased them (both used with 114,000 miles on the clock), and neither has leaked a single drop.
E39 (01-18-2018)
To answer your question about the leak relation with Synthetic oil, first synthetic oil has slight if not different property than conventional. The flow property and leaving a thin coating property probably different as well. My theory is that your seal has crack but the crack not large enough for seeping out conventional oil, however when synthetic being used and the extra protection property they has can goes through small cracks. which makes the people believe that synthetic oil causing the leak.
E39 (01-18-2018)
Latent car nut
Here are two photos of the original leak and the oil pump after I had taken it off the car. You can see the figure-8 gasket is by the screwdriver in the lower left of the picture. Good luck!
![](https://cimg5.ibsrv.net/gimg/acurazine.com-vbulletin/2000x1504/img_3110_8c4eeb98a52db0ad32ec6d732cac0ae6d577afee.jpg)
![](https://cimg2.ibsrv.net/gimg/acurazine.com-vbulletin/2000x1504/img_3143_dc5fb3424882f53b3e44903f221997163bbbdb8d.jpg)
I know my limits, but great job! And thanks for the video....wish that it only took 9 minutes in real - life.
Check out that compliance bushing. It looks a bit torn to me
SteveBean (01-17-2018)
There's a "thanks" button on the bottom right of each post
(on desktop site)
(on desktop site)
Is it the rear main seal? Rear main seals are known to stop leaking on their own sometimes on these cars. If it is just sweating just keep an eye on it it might stop leaking. Have you changed the pcv valve?
StealthTL-S (01-19-2018)
Latent car nut
Speaking of the rear main seal, I've never been inside a J-Series engine, do any of y'all know if, while doing a clutch replacement (mine will likely happen in the next couple of months), the rear main seal is easily accessible?
You have to remove the flywheel as well, in your case its MT so if you replace the fly wheel then yes I would get the rear main done at the same time.
horseshoez (01-19-2018)
Latent car nut
If youre sure its an oil pump leak, you should just replace it the next time you do the timing belt job and just top her off until then. Leak stopper products always fo more harm than good.
if you’re going to try and fix it, do it right or don’t do it at all
E39 (08-23-2020)
Latent car nut
What about a 40wt oil to try and slow the leak? Would a 40wt be okay with j35 tolerances and/or vtec functionality? Or would the higher oil pressure from the 40wt just be counterproductive in slowing a leak?
Latent car nut
Even if you put in the 10W-60 BMW uses for some of it's M cars, it wouldn't slow the leak.
E39 (08-26-2020)
Latent car nut
We certainly cannot tell you not to do it, but there is literally a 0% chance a 0W-40, 5W-40, or 10W-40 will help stem the leak.
E39 (08-26-2020)
Latent car nut
I've never heard of thicker oil slowing a leak. I have heard of it slowing it being burned or helping on a very worn engine to help maintain pressure due to internal oil flow losses (worn bearings, etc).
Pretty sure most of us have chimed in with similar guidance. What comes next is all up to you on what you are willing to try.
E39 (08-30-2020)
everything leaks eventually..
