2005 MDX power steering pump compatible with 2004 TL?
Old Aug 31, 2020 | 10:48 AM
kpayne111's Avatar
Just wondering if the pump is compatible as I acquired an mdx as a project and decided not to follow through, however the power steering works perfect. If it is, i amgonna try that pump on my tl to see if it improves my crappy power steering and issue where car always pulls to the left at speed, before i have the mdx picked up for scrap
Old Aug 31, 2020 | 11:10 AM
Ted Kief's Avatar
I would try a wheel alignment first My tl pulled to the right and the cure was a tire and alignment.
Old Aug 31, 2020 | 11:15 AM
kpayne111's Avatar
I had an alignment done last year, car was way more stable over bumps but still pulled to the left. The power steering is kind of weak when you have to work the wheel to get into a parking spot, not sure if the pump is the issue or elsewhere
Old Aug 31, 2020 | 11:48 AM
1. Go to www.oemacuraparts.com
2. plug in both car year and model to get the P/S pump part number
3. compare the part numbers on the power steering pumps to get your answer
Old Aug 31, 2020 | 12:15 PM
kpayne111's Avatar
the "sub pump assembly" for the tl is a 56110-rda-a01, and the mdx is a 56110-rdj-a02, seems kind of similar but not a perfect match
Old Aug 31, 2020 | 05:39 PM
i'm going to go with no then.
Just buy the seals and reseal your PS pump yourself. https://acurazine.com/forums/3g-tl-p...-scans-841134/
Old Sep 1, 2020 | 05:53 PM
kpayne111's Avatar
Turns out the pump is identical, I threw it on this afternoon and power steering feels excellent now. I guess I'll have to install the passenger side outer tie rod and get it aligned as it still wants to pull to the left a bit.
Old Sep 2, 2020 | 12:48 PM
The link below attempts to clarify Acura / Honda part numbers:
https://ultraracing-usa.com/blog/dec...-part-numbers/
Old Sep 2, 2020 | 12:59 PM
damn that's useful! It doesn't exactly determine whether parts or interchangeable, but still good to know the convention used for part numbers
Faded_TSX
Jan 21, 2026 01:20 PM
rdx158
1G RDX Problems & Fixes
Jun 11, 2015 01:18 PM
rdx158
May 22, 2015 06:24 AM
imakeholesinu
Dec 30, 2012 09:08 PM
aroundtheback2012
Feb 14, 2011 10:58 AM
