Oil Leak
Old Nov 16, 2006 | 10:50 AM
larryd's Avatar
Oil Leak
My 96RL has an engine oil leak. I've cleaned the engine, put a marker in the oil and rechecked for leak location, and I think it is an oil pan gasket leak. Anybody know the shop flat rate for repairing this item?
Larry
Old Nov 16, 2006 | 01:18 PM
mr.motoring's Avatar
checkmate...
Many times the oil pan gasket is the assumed culprit when it comes to oil leakage since only the pan appears to be very wet. However, keep in mind that any of the other oil seals could allow a trickle of oil to escape.
I find that the valve covers tend to leak more often and when they do, gravity pulls the oil down the block and it coats the lowest point of the engine, which is the oil pan.
Old Nov 16, 2006 | 01:19 PM
RaviNJCLs's Avatar
If it's just the oil pan gasket, it shouldn't be that much. It's probably one of the easiest to replace.
Mike734
Dec 10, 2021 01:25 PM
IBankMouse
Jun 13, 2020 12:53 PM
spudweb
May 22, 2016 02:39 PM
Avenger411
Oct 11, 2015 03:53 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
