Oil drain bolt
Old Dec 22, 2013 | 02:15 PM
allaces's Avatar
Oil drain bolt
so planned on changing filters today since its so nice out.
air filter and cabin filter done
oil change NOT done...i think king kong tightend the oil drain bolt that thing doesnt budge
Old Dec 22, 2013 | 03:28 PM
main70072's Avatar
Tried a cheater pipe?
Old Dec 22, 2013 | 03:38 PM
mzilvar's Avatar
The aluminum sealing washers expand a good bit once they're on and the car is driven and they heat up.
When I had the stock sealing washers on the car I always had to use a breaker bar to loosen the drain bolt. Just be sure not to tighten it with the breaker bar, the threads in the pan are aluminum and you don't want to damage them.
Old Dec 22, 2013 | 04:42 PM
LGcbp8's Avatar
Just hold the wrench on the drain plug and tap the wrench with a hammer. That should break it loose with minimal effort.
Old Dec 23, 2013 | 02:03 AM
dcmodels's Avatar
+1 and use a 6-point socket/ wrench
In fact, a sharp bump with the heel of my hand against the wrench end is usually enough - actually, the heel of my left hand against the fist of my right hand on the wrench - no need to bruise my hand.
Its not the torque of the bolt holding it - the aluminum washer actually galls (cold welds) to the aluminum oil pan and the drain bolt. That is why the bolt requires such high torque to remove. But a bump, or tap against the wrench, is usually enough to break the washer/ bolt loose.
As for the comment in the post above, in my opinion it will actually be easier to remove the bolt with a hot engine versus a cold one. And I prefer to drain the oil hot.
And the galling of the aluminum washer, is why I oil the washer (both sides) and use a lower torque when I reinstall the bolt - and use safety wire to prevent it from loosening - but I suppose most would consider that too much work. Just *habit* from my early days of racing bikes and required safety wiring.
You could also use a copper washer, which will hold just as well as the aluminum one at the proper required torque, but will not gall and be much easier to remove next time. Newer GM cars also use a synthetic washer, which also holds well and of course will not gall. I have purchased them from Pep Boys for use on my Chevy truck. And used one the last couple of times on my Acura RDX.
Old Dec 23, 2013 | 03:26 PM
allaces's Avatar
heated up engine and cheater bar....broke it loose thanks for the replies everyone
IBankMouse
Jun 13, 2020 12:53 PM
neuronbob
23
Jul 16, 2019 10:48 AM
Rcelestino93
Sep 23, 2015 10:01 PM
STL TL-S
Sep 23, 2015 08:52 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
