Oil Change
Old Apr 22, 2014 | 10:26 AM
bsunder11's Avatar
Oil Change
Hey need advice, I have an 06 tl base which oil should i use 5w20 or 5w30?
Old Apr 22, 2014 | 10:30 AM
5w-30 stays 'thicker' at operating temp than 5w-20. The first half is a viscosity rating for cold operation and the second is a rating for warm temp.
a thinner oil will be better for colder climates, while a 30 weight will be better for hotter climates
Old Apr 22, 2014 | 10:41 AM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
Either/both.
Old Apr 22, 2014 | 10:50 AM
^correct, either or will be fine for your TL
Old Apr 22, 2014 | 11:19 AM
Vlad_Type_S's Avatar
Registered Bike Offender
inb4 oil debate.
I agree with those guys. Either will be alright: depends entirely on the climate. I run 5W-30.
Old Apr 22, 2014 | 11:25 AM
i run 5w-30 as well
Old Jun 3, 2014 | 12:36 PM
tones160's Avatar
[x] FWCC [x]
Good i found this thread. I have a bit of a dilemma. I currently use Gastrol Edge 5w30 synthetic, the problem is that i have a whole bottle with 3 QTZ left which means i need an extra 1.5 QTZ. Would it be fine if i can probly mix the remaining of the 1.5 QTZ with Mobil 1 since i couldn't find small bottles for the Gastrol Edge. Please enlighten me, first time doing my own oil change *No flaming please*
Old Jun 3, 2014 | 06:15 PM
bla8291's Avatar
I'm running 10W30, which is perfectly fine, considering I live in Miami.
Old Jun 3, 2014 | 06:25 PM
tones160's Avatar
[x] FWCC [x]
I'm also planning on buying Mobil 1 5w-30 as well. Any in takes?
Old Jun 6, 2014 | 12:06 AM
I hate cars's Avatar
You can mix weights and brands. I would go with a good 5w-30 in 90% of the situations in North America. In really cold areas or if you do mostly short trips, a 5w-20 might be for you. Just remember these engines spec'd a 30wt years ago with no changes to the bottom end since then so don't be afraid of the 30wt oils.
There's a ton of info on oil weights and brands around here if you search.
mada51589
Jan 9, 2025 04:40 PM
robm
Sep 18, 2015 07:53 AM
ja4lyfe
ZDX
Sep 17, 2015 09:10 AM
HydrasunGQ
Sep 14, 2015 10:14 PM
datadr
Sep 12, 2015 09:12 PM
