Oh NOES! Coolant leaking from... from... WTF is that thing?
Changed my oil and ATF tonight, while under the car noticed dried up coolant on everything and that my reservoir was dangerously low (uh-oh).
changed oil, changed ATF, tracked down what the heck was leaking but I don't know what the heck it is. it's a 2004 AT (just for ref.) and the leak point is immediately above the rear engine mount.
What is it, is it costly, can I fix it, you guys rock, thanks for the help!
Is This Your Part?
#23??
Part#: 80220-S6A-013
Desc: VALVE, EXPANSION
Year/Model: 2004/TL
List $: 75.93
Disc $: 56.95
Maybe could be #12 too, I just can't tell for sure from the drawing.
http://www.acuraautomotiveparts.org/...s=&view=normal
I don't know what part it is for sure. Have your local dealer tell you to be sure.
Maybe I Hate Cars is more certain. If so, it's about a $17 part.
79710-SDA-A01 VALVE ASSY., WATER $16.95 $12.71
should I just clamp down the hose before and after the part and just replace it, or do I need to drain and refill the coolant?
Anyone know for sure which part it is?
Thanks guys!!!
Thanks guys!!!
Thread Revival...
Rule #1: Cardio.. lol..
Here's a link to the DIY for the heater control valve:
https://acurazine.com/forums/showthread.php?p=11381436
cycdaniel
Dec 17, 2019 10:58 AM
