Need Help ASAP!!!!!!!!!!!!!!!!
Old Mar 20, 2011 | 07:43 PM
donny0391's Avatar
So i was driving home today from the mall...smooth ride no potholes or anything ...was goin about 80 -50 mph ... so i got on the Belt Parkway and i hit dead stop traffic and when it finally stated to move my car didnt.... it felt like my car was in neutral cause i was pressing the gas and the engine revved but didnt move at all .. i put the car in park and shifted back to drive and it kicked in really hard after a few seconds and started to move again .... Has this happen to any of u and should i be worried cause no engine light came on or anything. Car drives normal like it did before ..
Old Mar 20, 2011 | 07:47 PM
csmeance's Avatar
judging by your avatar, you have a TL-S. It not engaging could be due to a torque converter issue. How many miles do you have on your car? Have you changed the fluid at all?
I'm thinking that the fluid was hot while you were driving and sitting in traffic, it got hotter. With such hot fluid right near the Torque converter, it slipped. But when you put it in park and then back in drive, the engagement of other stuff moved cooler thicker fluid and allowed it to engage.
Old Mar 20, 2011 | 07:53 PM
donny0391's Avatar
I'm thinking that the fluid was hot while you were driving and sitting in traffic, it got hotter. With such hot fluid right near the Torque converter, it slipped. But when you put it in part and then back in drive, the engagement of other stuff moved cooler thicker fluid and allowed it to engage.
what fluid are u talkin about i have no idea what torque converter fluid is?
Old Mar 20, 2011 | 07:57 PM
warren4066's Avatar
check your battery cables to see if they are on tight
Old Mar 20, 2011 | 08:09 PM
donny0391's Avatar
What does the battery have to do with this this problem..if it was the battery woulndt the car shut off with no power
Old Mar 20, 2011 | 08:20 PM
stiffdogg06's Avatar
Get Money
I take that as a no.
Your transmission fluid.
Old Mar 20, 2011 | 08:29 PM
donny0391's Avatar
o0o well yea i changed that about 20,000 miles ago
Old Mar 21, 2011 | 12:53 AM
jimmyl's Avatar
Plastic schmastic
Why ASAP????
Highly overused.........
Old Mar 21, 2011 | 01:09 AM
jpgayan's Avatar
2007 TL Type-S NBP
Car that suddenly becomes unmovable with no warning in the middle of traffic? That's effectively in the Yugo category as a daily driver in my book. I can't afford to be missing work or school because my POS Honda transmission isn't working. I imagine it's the same for this kid. Hence, ASAP!!!!!!!!!!!!!!! To OP, put your year/model/other info in your signature line so people know what car you have and what mods you've done. It makes it a LOT easier for people to help you troubleshoot on stuff like this. It sounds similar to the earlier Honda trans problems but I was under the impression that they had pretty much cleared up by late third gen.
Old Mar 21, 2011 | 05:13 AM
paperboy42190's Avatar
Just a note, the car will not shut off if the battery is disconnected while driving. Some electronics wont work, but engine will run and drive. I say from experience
Old Mar 21, 2011 | 05:54 AM
ggesq's Avatar
AJ-it's not an S. It's an 05 w/ a Type-S badge
donny- good luck with finding out what the issue is.
Old Mar 21, 2011 | 04:06 PM
donny0391's Avatar
Thanks for the help j hope it's not the tranny . The car drives normal I think it cud have something to do wid the converter over heating . Could that cause the car to do this
Old Mar 21, 2011 | 04:19 PM
jda123's Avatar
Dogmatic Dinosaur
It is possible. i would change the transmission fluid and see. Just do a single 1x3 drain and refill with some quality fluid (not Honda fluid).
Old Apr 11, 2011 | 06:23 AM
donny0391's Avatar
Tranny or computer?
Iv been having a problem with my tl and it's time to fix it, at first I tought it was my flex pipe over heating so I removed the torn up mesh cylinder on the outside of it and that didn't work because today on my way to work it happened agian for the third time , while driving I have no problem but when I came to a stop this morning and the light turned back green the car wouldn't move it felt like the car was in nutral . I pressed and pressed the gas but the car wouldn't move just reved and finally after about 2 mins in the middle of a highway it started to move like normAl ,I was close to work so I drove about 10 blocks and then pulled over to check it out . All of the lights on my dash was on - VSA, seatbelt engine light even came on and where it usally shows What gear the car is In, that D was blinking ...could this be the computer or the tranny cause my bro told me his m3 had the same problem and it was the computer that's why I'm guessing computer but in the other cause these are tranny failure problems . How can u tell if ur tranny is done?
Old Apr 11, 2011 | 06:57 AM
donny0391's Avatar
Old Apr 11, 2011 | 07:03 AM
yeah, please give time for members to actually wake up and respond.
Blinking D is not good.
if it threw codes, have them read free at an auto parts store.
Old Apr 11, 2011 | 08:56 AM
VQPower37's Avatar
blinking d is usually indicative of a failed tranny
Old Apr 11, 2011 | 09:28 AM
05AV6's Avatar
Def sounds like a tranny failure at this point. I would suggest having the codes read, when was the last time you drained and refilled your tranny fluid?
Old Apr 11, 2011 | 05:17 PM
donny0391's Avatar
Took it to a Shop Today and they said it was the tranny =;( ...they said the cod was 704 or somthing ..he said its a internal tranny failure ...what should i do???? Should i get a new tranny from oem or get a rebuilt one and does anyone knoe where i can get a rebuild one
Old Apr 11, 2011 | 06:47 PM
donny0391's Avatar
Yea I TOught So =/
Old Apr 11, 2011 | 07:04 PM
ggesq's Avatar
Honda does not sell new transmissions.
Old Apr 11, 2011 | 07:10 PM
ez12a's Avatar
the overexplainer
6mt conversion.
Old Apr 12, 2011 | 05:02 AM
donny0391's Avatar
Well I just got to work and didn't drive over 30mph but no problem getting hare and the check engine light came off do any of u guys think it's just the oil cause the guy told me it's burnt to shyt ?
Old Apr 12, 2011 | 06:23 AM
flyromeo3's Avatar
did you change the tranny fluid again?
Old Apr 12, 2011 | 08:56 AM
Comptechtl2367's Avatar
Once your trans throws that code your trans is done, it wont magicly fix itself over night. How many miles do you have? I would look into a used trans with low miles if you dont have the money to get reman.
Old Apr 13, 2011 | 06:53 PM
donny0391's Avatar
Yea man i changed the tranny fluid yesterday, butt im driving under 40 mph...cause i need the car this week for work ...but on sunday ill push it faster to 70 and see if it happens again ...but so far the car is driving perfect and the engine light went away after the first day it came on ..
Old Apr 13, 2011 | 07:03 PM
donny0391's Avatar
i have 71,000 and the check engine light went away in one day ...ill rebuiled the transmission but how much u think its gonna cost me ?
Old Apr 13, 2011 | 07:05 PM
^call around. get the best estimate.
Old Apr 13, 2011 | 07:17 PM
donny0391's Avatar
=/ im guess more than 2000..is it gonna be more than 2500 ...
Old Apr 13, 2011 | 07:37 PM
I hate cars's Avatar
Did you check the fluid level before you did the drain and fill?
The code is only comparing input vs output speeds so it doesn't matter if its slipping from a low fluid level or it the clutches are worn out. Its possible the fluid boiled which will give the same symptoms as being low. A good synthetic will have a much higher boiling point. I would try Redline racing and see if it does this again. If not, I would try and find the source of the heat. Did it puke out of the breather at all?
Old Apr 13, 2011 | 10:24 PM
tintedtl05's Avatar
Are you still under powertrain warranty? Did you buy the car new or CPO. I'm having the same issue and a rebuilt is around 2800 18mo and 3900 new 3yr warranty new. Hopefully I'll be covered this upcoming tuesday, my main seal is gone and leaking transfluid like a barrel full of monkeys.
Old Apr 15, 2011 | 07:30 PM
donny0391's Avatar
IM not sure what a breather is but it didnt puke anything. I Used honda fluid this time. When i took it to the shop they checked the oil and it smelt burnt and was realy black .. Could these problems be cause because of loose battery cables ?Because my battery cables were really really loose.
i have no warranty at all =/
njresendez
3G TL Photograph Gallery
Sep 21, 2015 06:32 PM
Skirmich
Sep 15, 2015 06:41 PM
Billu99tl
Sep 13, 2015 11:30 AM
