Motor Mount Bolts Spinning
Old Aug 28, 2018 | 04:45 PM
Jake DeGazio's Avatar
3rd Gear
Hey Guys,
Yesterday I was trying to change the front motor mount on my 06 TL, and I realized that the bolts that hold the mount to the subframe just spin. it looks like there was a nut underneath it that was welded to the subframe, and the weld broke possibly.
Has anyone else ran into this issue?
I was thinking maybe putting JB weld on it, letting it sit for a few days and spraying it with penetrating fluid keeping my fingers crossed?
Old Sep 16, 2018 | 07:23 PM
Galco's Avatar
5th Gear
Should be able to put a boxed end of a wrench on the underside of the mount bolt and trap it under there as you work from above. Else have a helper hold wrench.
try JB weld but not likely to hold as these bolts should be around 50 ft/lbs tourque.
rk5n
Nov 18, 2020 08:15 PM
Mike
Sep 3, 2009 09:28 PM
StonedCL
Jan 24, 2009 11:56 AM
dasuddith33
2G CL Problems & Fixes
Nov 20, 2008 12:08 PM
NOMAD
Oct 24, 2002 12:54 PM
