Many Tiny Issues
Old Sep 9, 2018 | 11:55 AM
  #41
Dhiren314's Avatar
I got an update for you all.
1. I知 stupid, I tried so hard to take the clips off the bracket but all I had to do was move the holder closer to the block instead of pinch it. And after that things were easy. Taking the sensors out were easier than I expected with the PB soaking for days.
2. My back sensors wiring was covered the grease and goo from my inner cv joint when that went bad a while back and gave me a head gasket scare.
3. Your knuckles will hate you after this.
4. Finally, both sensors looked all types of black and carboned up so good thing I went ahead and changed it.
Hoping this helps the MPG
Old Sep 9, 2018 | 10:42 PM
  #42
Dhiren314's Avatar
Little update I also got a Bt45-Hon3 put in and I知 loving it.
Took the car out for a little drive and the mpg seems to be on the rise. But now I have another issue, my VSA light is on and the Triangle also won稚 go away, I did a scan for codes and found nothing, car drives normal but I can feel some hesitation when I知 accelerating out of a turn.
Old Sep 10, 2018 | 11:55 AM
  #43
DO yourself a favor. When you come across an issue like that, go to google.com, type in site:acurazine.com and then your issue (in this case, VSA light /triangle)
https://www.google.com/search?q=site...hrome&ie=UTF-8
It's a somewhat common issue with our cars and the thread above will give you some guidance on how to fix it.
frazer830
3G RDX Problems & Fixes
18
Feb 27, 2021 10:32 AM
Rustito
Wash & Wax
Oct 25, 2001 07:08 PM
