Many Tiny Issues
Old Sep 3, 2018 | 03:37 PM
Dhiren314's Avatar
Many Tiny Issues
I got an airbag light that comes on randomly so I thought I’d plug in my scan tool to see and well it can’t see srs codes, thought it did. But I did get a 61-1 Battery Voltage Malfunction code, I assume the srs code is something to do with my belt because when it’s on I can drive without my seatbelt no issue, I still put it on but it doesn’t recognize if it’s on or off. I’ve tested my voltages and they seem fine 11.9 before crank and then 13.9 when the engine turns over. The other issues with the car is the fact that the driver side mirror keeps trying to go up after that reverse feature for the car, both side mirrors don’t move smooth so I have to relubricate them, then the door behind the drivers will not lock or unlock from the key fob(tried both) in hot weather, which is all the time in Cali. The car also get really bad gas mileage, I know it’s old and has 120k but I think 14 city without ac running is still really bad, that’s with driving like a grandma anything more and it’s straight 11 mpg.
I don’t know what’s causing all these issues. They could all be related and I’m just stupid or they are all Seperate and would take a lot of time.
Thanks ahead to all of you that respond
Old Sep 3, 2018 | 05:54 PM
redbeard1's Avatar
Hi,
The code is probably due to the low voltage. A fully charged healthy battery should register 12.7 volts A 50% charged healthy battery should register 12.3 volts. Assuming your battery is healthy, 11.9 volts is usually indicative of a battery near empty. Use a trickle charger to get your battery to full. Alternators are not meant to charge an empty battery.
The airbag light is a common problem. Google on this site. I need to clean my seat belt buckle receptor every year or I get the same light. One poster said that if you buckle before starting the car, the problem also goes away.
Good luck.
Old Sep 3, 2018 | 05:57 PM
Dhiren314's Avatar
Sadly this code was there when I got a new battery as well. I know the HFL has a parasitic drain on the battery but I do use the homelink for my garage door and I’m scared that if I unplug the HFL homelink would also go away. I’ll charge the battery and see what happens
Old Sep 3, 2018 | 06:02 PM
redbeard1's Avatar
Ymmv but I disconnected/removed my hfl and still use the home link to open my garage door.
Old Sep 3, 2018 | 06:04 PM
Dhiren314's Avatar
Good to know thank you for the info
Old Sep 4, 2018 | 01:45 PM
Scottwax's Avatar
Mr. Detail
Good luck.
That's what I learned to do. Supposedly Honda and Acura warranty seatbelt issues for the life of the vehicle. I know they fixed an issue on my 1990 Accord years ago when it was well out of the regular warranty. My understanding is if the airbag light doesn't flash provided you buckle up first, the issue is in the seatbelt system and should be fixed for free. But if it turns out to be something else they will charge you a diagnosis fee.
Old Sep 4, 2018 | 02:52 PM
Dhiren314's Avatar
So far I don’t have much luck with this car so I am willing to deal with the light and try to clean or do the buckle beforehand. The main killer is the 14mpg, I don’t even know how to fix it.
Old Sep 4, 2018 | 02:57 PM
quantum7's Avatar
14 mpg is bizarre. I get 26 mpg on my 07 with almost 270,000 so you have something going on. Have you put an OBD II on it to see if you have any other codes related to engine? Even if you drive all city you should be around 20 mpg.
Year/service history??? 120,000 is just getting warmed up for these cars
Old Sep 4, 2018 | 03:00 PM
Jackass's Avatar
Start with posting the details on the MID that include the average speed as well. These cars are pigs when in true stop and go traffic. Mine recently dipped into the high teens for the first time in years....but then I noticed my average miles per hour was sub-25.
Old Sep 4, 2018 | 03:03 PM
Homelink is powered by another circuit, when you "unplug HFL" , you're unplugging the HFL circuit , it has nothing to do with homelink.
Old Sep 4, 2018 | 03:16 PM
horseshoez's Avatar
Latent car nut
Yup, 14 mpg is scary low; as suggested, post a photo of your MID showing your average speed. The thing is, even the most efficient car in the world can return 14 mpg if the average speed is low enough.
The above said, most folks will tell you under normal mixed driving conditions 25 to 30 mpg is more typical. My car typically returns 28-29 in "daily-driver" or "commuter" mode and more like 33 on the highway; the worst I've gotten when stuck in lots of traffic was 25.
Old Sep 4, 2018 | 03:23 PM
Dhiren314's Avatar
I do a lot of city driving so I understand the bad mileage I would just like it to be near the 17-20 range.
Average speed shows 23. I drive like 80% city roads just because it’s faster to get to places via the street cuz the freeway is always packed where I live.
Old Sep 4, 2018 | 03:43 PM
Dhiren314's Avatar
05 auto TL with 120k. I got it at 101k and have changed the oil and filter with Mobil 1 synthetic every 5k and the trans fluid 3x3 every other oil change. The owner before me took it to a the dealer about every 7,500 miles. So it’s been maintained engine and trans wise. I tried to pull all the codes I could I even ran some 02 sensor tests, drive tests, and checked nothing seems out of the ordinary. I drive like a grandma on most days so it’s confusing but I just chucked it up to old and high mileage.
Old Sep 4, 2018 | 04:04 PM
horseshoez's Avatar
Latent car nut
A few comments:
  • Changing your oil every 5,000 miles with Mobil 1 is serious overkill for these engines; changing Mobil 1 (or any other top quality synthetic) every 10,000 miles is still conservative and will allow the engine to far exceed the life of the rest of the car.
  • Doing a 3x3 ATF change every 10,000 miles is also overkill, but to a lesser degree; 15,000 to 20,000 miles is still very conservative.
  • At 120,000 miles your engine is barely broken in; my car has over 140,000 miles on it and as I wrote above, the absolute worst tank I've ever had on the car was 25 mpg.
Old Sep 4, 2018 | 04:17 PM
Dhiren314's Avatar
A few comments:
wow I’ve gone overkill on a lot of things it seems. I’ve just been used to changing at 5,000 cuz my dad preached it and because the amount of city I drive and I know city driving is hard miles, but I’ll try the 10k interval instead.
I wish my worst tank was 25, 11 is my worst tank and what I averaged for a while.
Old Sep 4, 2018 | 04:55 PM
redbeard1's Avatar
I spray electrical contact cleaner in the buckle receptor and then insert/release the buckle 20-30 times. Place a rag under buckle receptor in case the fluid leaks out. Keep in mind, if your airbag light is on, that means your airbags will not deploy in accident.
As far as your MPG, I get 33 highway at 65 mph with no head or tail wind and average 18 in city. WHat MPG do you get on highway?
Old Sep 4, 2018 | 05:23 PM
horseshoez's Avatar
Latent car nut
With a lot of city driving and with your fuel economy I might be inclined to go the recommended 7,500 miles, if for no other reason than until you get the fuel economy issue sorted (BTW, I'm leaning toward one or both upstream O2 sensors being in slow failure mode), I suspect there may be some fuel dilution issues. If you're really curious, go 7,500 miles and send an oil sample to Blackstone Labs and have the oil analyzed, it'll tell you if you have any fuel dilution issues (or any other issues).
Old Sep 4, 2018 | 05:56 PM
Dhiren314's Avatar
for the rare chance I get to go on the highway I get around 24 mpg.
Old Sep 4, 2018 | 05:58 PM
Dhiren314's Avatar
I have been pondering on the Blackstone idea for a while. I had a feeling that an o2 sensor has gone close to bad it makes the most sense to me. Imma get that lab done next oil change and see what comes back
Old Sep 4, 2018 | 06:00 PM
horseshoez's Avatar
Latent car nut
Way low.
I am not a fan of throwing parts at undiagnosed problems, however, far too often I've seen cars with relatively crappy fuel economy and no OBD codes have a sudden improvement in economy when the upstream O2 sensors are replaced. Should you be so inclined to try this, I cannot stress enough for you to buy either Honda/Acura OEM sensors or Denso sensors; whatever you do, do NOT buy Bosch units.
Old Sep 4, 2018 | 06:04 PM
Horsie, realize OP is in Cali and traffic is horrific out here. I get about that mileage as well and I take it as normal. The one time I took it out to Vegas doing normal cruising speed (70-75 mph over 200 miles) I was able to get 28 mpg. But the best I've gotten in Socal highway traffic and about 15% city driving is 26 MPG.
Sounds relatively normal to me but maybe my Type S is just as bad
Old Sep 4, 2018 | 06:14 PM
horseshoez's Avatar
Latent car nut
Hmmm, I suppose that's possible, but your's sounds low as well. My latest round-trip to the NYC metro area included a number of traffic snarls and it was a hot and humid weekend so the A/C was running full-tilt. During the trip, while the traffic was moving, I ran pretty much 70-80 the entire way, and still got 33 mpg on the trip down and 32 on the way back up. I'm having a hard time believing a Type-S, with only 0.3 liters of additional displacement compared to my car, will suffer that much in the fuel economy department.
Dare I add a side comment; last time I checked, California gas stations typically sell 91 AKI Premium, here in New England 93 is the norm and 91 is as rare as 93 in your neck of the woods; could it be possible the extra detonation resistance is responsible for the extra efficiency?
Old Sep 4, 2018 | 06:16 PM
Also Auto vs. manual
Old Sep 4, 2018 | 06:18 PM
Dhiren314's Avatar
Yeah I’m in the IE and the 15 is a killer in the mornings and so is the 91.
Old Sep 4, 2018 | 06:21 PM
horseshoez's Avatar
Latent car nut
I suppose, but a Type-S Automatic has the same highway fuel economy ratings as a 2006 6MT model; both are rated at 26.
Old Sep 4, 2018 | 06:37 PM
Dhiren314's Avatar
Way low.
I second the OEM or Denso. Do you know how much do they normally run?
Old Sep 4, 2018 | 06:39 PM
www.oemacuraparts.com
Go in and search for all the parts to your heart's desire!
Old Sep 4, 2018 | 06:43 PM
Dhiren314's Avatar
the 91 mighty have something to do with it but I doubt it would be that significant, if I run ac full tilt I’m certain id get 11 mpg. The car runs strong and I love it but she’s a drinker for sure.
Old Sep 4, 2018 | 06:44 PM
Dhiren314's Avatar
i thank you very much
Old Sep 5, 2018 | 12:44 PM
Dhiren314's Avatar
Just checked the sensors on the car and seems that the one behind is Denso while the one in front is Bosch. I plan on replacing both for Denso 234-5010.
Old Sep 5, 2018 | 12:53 PM
ahh that might explain some things.. Someone probably replaced it with a Bosch to fix an issue and it didn't fix it so they sold the car. Replace!!!
Old Sep 5, 2018 | 04:23 PM
Dhiren314's Avatar
Since it’s harder to get the back one they probably didn’t want to change it cuz general rule is to change them in pairs.
Old Sep 6, 2018 | 09:15 AM
Jackass's Avatar
Note that I replaced my factory O2 with that DENSO...my OE was an NGK. They do look different....not sure if that is a good or bad thing yet. I also only changed the front one and not the back....mostly out of laziness, cost, and only the front bank threw a code. As painful as it was to get the front one replaced, I for sure am not looking forward to doing the back one.
Old Sep 6, 2018 | 03:09 PM
Dhiren314's Avatar
I’m still waiting for mine to come but yeah I’ve seen some videos on it, doesn’t look fun or something I’m looking forward to but I’ll see how it goes
Old Sep 7, 2018 | 08:15 AM
Jackass's Avatar
I replaced mine on a Saturday, so starting on Monday I was hitting it with PB Blaster every night. I ordered an O2 socket from Amazon, and had tried a few times through the week just wrenching on it...and it never budged. I finally hit it with an electric impact on Friday night, and then Saturday morning I got it free with my wrench. Getting the stupid clip undone was also a PITA, but the videos I watched clued me in on how that worked.
Old Sep 7, 2018 | 01:44 PM
Dhiren314's Avatar
i got mine from amazon too, yeah I’ve been soaking them in PB to break up the rust and it’s being heat welded. I don’t have a strong impact so this should be fun, mine comes Sunday so imma end up doing it Sunday.the back ones gonna be a PITA for sure, and man I hope I don’t break the clips cuz I’ve done that to our old Van when I replaced the sensors for it.
Old Sep 7, 2018 | 09:52 PM
Jackass's Avatar
Just remember the clip does NOT come undone until it is released from the bracket.
Old Sep 7, 2018 | 10:59 PM
Dhiren314's Avatar
to my knowledge the back one is on a bracket, that’s the one you’re referring to correct?
Old Sep 8, 2018 | 11:28 AM
Jackass's Avatar
I "think" they both are mounted on a bracket that is part of the clip assembly. I haven't touched the rear one yet...just the front. Had to use a small flat head screwdriver to free the clip from the bracket. Only then can you separate the connector.
Old Sep 8, 2018 | 12:46 PM
Dhiren314's Avatar
well changing them out should be fun. I’ve sprayed them in pb blaster for the last few days. If it doesn’t come off Sunday imma use my atf/acetone mix and see how that works
