Maf
Old Jun 23, 2013 | 06:20 PM
jaw5983's Avatar
Maf
Anything special I need to know about cleaning my maf on 2006 tl, also is their anything special I need to know about removal, ps this is my first acura lol
Old Jun 23, 2013 | 06:22 PM
paperboy42190's Avatar
theres a MAP sensor, but I dunno about MAF
Old Jun 23, 2013 | 06:28 PM
jaw5983's Avatar
no maf???, shows how much I know about my acura lol
Old Jun 23, 2013 | 09:23 PM
Comptechtl2367's Avatar
No MAF on Acura/Honda. What are you trying to clean?! It has MAP sensors.
Old Jun 24, 2013 | 06:19 AM
Project_CLean's Avatar
MMkay.
Do you have a problem or were you just trying to clean it? No Maf in the 3G.
Old Jun 24, 2013 | 06:52 AM
jaw5983's Avatar
Im having a prob with rough idle at cold starts, it idles about at 1000 rpm at cold start is that norm.
Old Jun 24, 2013 | 08:02 AM
MMkay.
Well, what happens when it warms up? Do you have any additional components on at the time?
Is it a rough idle as in a misfire?
Old Jun 24, 2013 | 02:58 PM
pohljm's Avatar
rough idle at cold start is pretty common. check your EGR valve as well.
Old Jun 24, 2013 | 08:44 PM
jaw5983's Avatar
How much does a new EGR cost??, I was also thinking it might be the air idle control valve, I think that's what its called, or the temp sensor??
Old Jun 24, 2013 | 08:49 PM
you wouldnt have to buy a new egr valve.
just take the bolts off of it, lift it off, inspect it, and then clean if necessary.
Originally Posted by 94eg!
IT's the small black canister looking thing pointed out in the lower left corner. Unplug it, remove two nuts at the base, pop the whole valve assembly off...
Once you take it off (small circular valve is to the left).
Old Jun 24, 2013 | 08:51 PM
jaw5983's Avatar
How would I go about cleaning it??
Old Jun 25, 2013 | 07:42 AM
MMkay.
OP, you should read up a little more around the forum.There's plenty of information here,and you're not the first one to experience any common "issues" with our 3G's. The fact is,there's a lot of common problems that happen to a lot,if not all of us.
As for cleaning the EGR, you can take some brake cleaner and clean out the internals. Sometimes they have lots of carbon buildup,and can make your engine run rough. But as pohljm mentioned,for these cars it is pretty normal to have a little bit of a rough idle at cold start.
How long have you had the car?
heykosal
1G RDX DIY & FAQ
Nov 16, 2020 03:59 PM
TheWrench116
25
Nov 1, 2015 12:24 PM
hrothgar02
Sep 28, 2015 11:08 AM
Big mo
4G TL Problems & Fixes
Sep 12, 2015 07:22 AM
DDTsx06
Sep 8, 2015 06:56 PM
