Left Lower COntrol Arm
Old Nov 6, 2013 | 07:50 AM
bignutz's Avatar
I hit a curb the other night and the front tire is not centered anymore in the fender well. I think I bent the lower control arm. I have only found them for around $360. Does anyone know a better price I can get it for?
Old Nov 6, 2013 | 09:26 AM
erdoc48's Avatar
06 Anthracite TL
As much as that is, I'd stick with OEM for suspension parts. Look at different sites for parts like OEMAcuraparts.com.
Old Nov 6, 2013 | 10:18 AM
DMZ's Avatar
DMZ
Head a da Family
Or acuraoemparts.com. I wouldn't be afraid to use aftermarket parts in this situation. In some cases, they're actually better than OEM. Like the rear control arms which are adjustable on the aftermarket ones. Try Rockauto.com for comparison purposes first
Old Nov 6, 2013 | 12:19 PM
94eg!'s Avatar
#1 Super Guy!
I have never heard of ANY aftermarket adjustable control arm lasting nearly as long as OEM. Additionally you won't find any adjustable front lower control arms on the market for this vehicle. For a front LCA, OEM will be best (even used OEM).
BTW: Don't just replace an expensive LCA without knowing the problem for sure. You could have damaged any number of components under there and ended up with the same result. Have you ruled out:
- damaged subframe
- damaged knuckle
- damaged tie-rod
- damaged ball joint
Old Nov 6, 2013 | 01:18 PM
bignutz's Avatar
Well a tire shop told me that the control are was bent, and possibly the knuckle and tie rods. I did a little research on this and a lot of people with the same issue replaced the control arm and got it aligned and the knuckle seemed to be fine. So I figured I would start with the control arm and when getting aligned they would tell me if the tie rod is bent, but not sure if this will work.
Old Nov 6, 2013 | 04:54 PM
Turbonut's Avatar
Look for a used LCA in your area:
www.car-part.com
Old Nov 25, 2013 | 08:30 AM
bignutz's Avatar
Thanks for the site. I was able to order all my parts and have some money left over to get the a spec skirt for my tl type s.
cycdaniel
Dec 17, 2019 10:58 AM
marcelft
Jul 10, 2018 06:17 PM
Aging-Hacker
Oct 5, 2015 11:44 AM
njresendez
Sep 21, 2015 11:23 AM
gqdabien
Sep 8, 2015 11:41 PM
