led drls problem
Old Nov 24, 2009 | 01:02 PM
tinteduptls's Avatar
The TINT CEO
led drls problem
i just goty sum led for my drls and i put one in and it worked and after i put the second one in it neither worked does anyone know why ?
Old Nov 24, 2009 | 01:49 PM
BlacuraTLTYPES27's Avatar
I believe you need to get a resistor of some sort to make that work. im sure someone else will be able to give you specifics
Old Nov 24, 2009 | 02:44 PM
zsameer's Avatar
i added leds for my fog light in my 05 and one bulb lit up fine and the other one was dim. i had to switch the polarity on the one that was dim and that fixed the problem.
Before.....
After......
Old Nov 24, 2009 | 03:39 PM
Jerseyjoe23's Avatar
6th Gear
Damn thats bright ! What kind of led is that ?
Old Nov 24, 2009 | 04:29 PM
zsameer's Avatar
I can't remember the make or who the seller was but i bought it off of ebay. I think it wasn't too expensive either. Maybe 20 something. In my avatar pic those are the LED's so they are bright enough for sure. This is the closest thing to it for the price range i found on ebay today....
http://cgi.ebay.com/ebaymotors/SMD-9...Q5fAccessories
and
http://cgi.ebay.com/ebaymotors/2xWhi...Q5fAccessories
Old Nov 24, 2009 | 11:35 PM
Steven Bell's Avatar
I just had the same exact problem too. I ordered two halogen bulbs for it instead. I just want a whiter bulb, not a brighter bulb. I'm going to send back the LED's. I didn't know that reversing the polarity would solve the problem.
Old Nov 25, 2009 | 08:04 AM
zsameer's Avatar
I thought there was something wrong with the bulb so i swaped it with the good one and that did the same thing so i knew it was not the bulb so made some jumpers and tried from the battery and switching the polarity worked. I also wanted a whiter bulb to go with the HIDs.
Old Nov 25, 2009 | 05:42 PM
The TINT CEO
i e mailed vleds.com they said i need the daytime running light module and i was browsing through threads and i see that the module wont fix the problem do i need the resistor harness
Old Nov 25, 2009 | 09:58 PM
rockyfeller's Avatar
King of NYC
If you have a 07+ TL the reason is because your DRLs don't run at 12V. That is the reason why the OEM bulbs run dimmer than typical 55watt bulbs. The LED bulbs you are putting in there require 12V. There is an old thread about it somewhere if you search.
Old Nov 25, 2009 | 11:05 PM
Yes, that is true-I didn't want to go to all that trouble, so I ordered the halogens. I'm going for a whiter light, not a brighter light. Thus my decision.
Rocky, I knew you would know the straight scoop on this. The dealership thought it was 12 volt, since everything runs on 12 volt on the 2007+ TL's.
Old Dec 3, 2009 | 07:55 AM
The TINT CEO
ok so i bought the drl module from v leds n now my leds work but the drl indicator is on in my cluster what do i need now?
Old Dec 18, 2010 | 03:59 AM
CarbonBronzeRocketTypeS's Avatar
That's exactly what I just ran into myself I just installed LED DRL's from iJDMtoy with the "special drl decoders" that supposebly get rid of the DRL error in the dash. My DRLs light up but are not as bright as I thought they should be and my DRL lights still come up on the dash although I have the whole decoder kit installed correctly any help would be appreciated. I bought this kit for my 08 TL Type S ---> http://store.ijdmtoy.com/9005-LED-Da...d_sku45_r3.htm
Old Dec 18, 2010 | 04:55 PM
CubanLynx84's Avatar
under renovations....
I had the same issue with mine and I got them from Vleds. James has actually helped me alot with this but I am still at a loss. Right now I'm running mine without any harnesses from the kit at all. I don't have any codes either. But now I have a new issue my drls go off after some time and I don't know why. I'm thinking without a resistor they're heating up and cutting off to cool down then turning back on. The harness that came with the kit actually made the car throw a drl code. And with the resistor harness alone they don't light up as much as they do without it.
I'm wondering if there is anyway to wire in the resistor alone or maybe the polarity is wrong like stated before
sockr1
Oct 1, 2015 01:31 AM
usual.acura
3G MDX (2014-2020)
14
Sep 19, 2015 05:01 PM
JnC
Sep 11, 2015 06:06 AM
spiel08
Sep 7, 2015 08:19 PM
Fadij
Sep 2, 2015 08:31 PM
