Leaky Sun Roof
Old Jun 18, 2008 | 10:41 PM
Rocky Shore's Avatar
Leaky Sun Roof
I just took delivery of an 08 TL on May 31. I have an issue that dealer states they can't fix. (Read design flaw). Any how, parked the car at work nose down on a slight incline, we then get about 4 inches of rain through out the day and when it is time to go home the passenger floor board is soaked. Take to dealer on Monday, they clean the sun roof tube. Fast forward one week later same thing happens again. Go back to the dealer, say that there is nothing they can do. Only suggestion was don't park on a hill in a rain storm. Any suggestions?
Old Jun 18, 2008 | 11:33 PM
Will Y.'s Avatar
Registered but harmless
Originally Posted by Rocky Shore
Any suggestions?
Yes- I'd suggest you go to a different dealer's service department.
I have not heard of TL sunroof leaks being an issue except where the drain tubes were clogged. Do you know if the leak is from the sunroof?
G/L with this, and welcome to AZ.
Old Jun 18, 2008 | 11:40 PM
Will Y.'s Avatar
Oh, and here is a short thread that mentions the source of every interior water leak problem I've seen on this forum: https://acurazine.com/forums/showthr...ater+leak+seat
Old Jun 19, 2008 | 01:00 AM
01tl4tl's Avatar
call acura 1-800-382-2238 x5
report the attempted repair and blow off- ask for a manager to call you back
Old Jun 19, 2008 | 01:16 AM
carlos9827's Avatar
2011 BMW 335i
Old Jun 19, 2008 | 07:09 AM
LoveMyTL-S's Avatar
May want to have your A/C drain hose checked. I've heard of cases where this causes the water to leak into the passenger side flooring.
Old Jun 19, 2008 | 07:15 AM
LoveMyTL-S's Avatar
Perhaps this thread may help:
https://acurazine.com/forums/showthr...ght=water+leak
Old Jun 23, 2008 | 02:37 PM
1995hoo's Avatar
Keep Right Except to Pass
Make sure the drain tubes are properly connected. Sounds crazy, but I had a similar problem with my 1986 Legend about ten years ago when it rained almost every afternoon for about a month—some water fell on my head when I opened the moonroof shade. Turned out one of the drain tubes wasn't even connected for some reason. (I had bought the car used, and the previous owner used a mechanic whose competence I had reason to question, so who knows if he had screwed something up.)
Old Jul 1, 2008 | 10:25 PM
Update
Hey all, we have been unindated with copius rain events. In one case we received 8 inches over a days time. I went back to the dealer a third time and in this case the car was sitting level. I think the seals are the current suspects in either the front or back doors on the passenger side.
Old Jul 1, 2008 | 11:36 PM
csmeance's Avatar
Suggestion, park in that same spot and have someone hose the car, you sit inside and find the leak. Take the glovebox out if needed, along with some minor panels to help you find it. DIY's on this are all in the 3G garage.
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
12vancover
Oct 16, 2015 12:04 PM
jmaxima03
Sep 27, 2015 10:22 AM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
spoiler900
Sep 23, 2015 04:41 PM
