Knock Sensor
Old Dec 23, 2008 | 03:06 PM
05TLon22s's Avatar
Knock Sensor
Does anyone have any idea on how to replace a Knock Sensor on a 2005 Acura TL? I would rather take a whole Saturday to get it done instead of paying 501.92 to have it done at the Acura Dealership.
Old Dec 24, 2008 | 01:47 AM
drunkm0nk3y's Avatar
are you getting a cel light p0325? wow 501.92 the knock sensor is only 28 -30 dollars.
Old Dec 24, 2008 | 12:52 PM
05TLon22s's Avatar
Not sure what the code number is the guy didn't give it to me. But I took it to one of the local Acura dealerships and they said it was the knock sensor.
Old Dec 24, 2008 | 01:17 PM
Fulani has a TL's Avatar
Take it to Autozone and get it checked for FREE!! They will give you the code tooo
Old Dec 30, 2008 | 01:09 PM
whats your email. i'll send you the pdf pages for the job. its an easy job. if you are mechanically inclined. i just replaced mine over the weekend due to the rat chewing the wire out.
couple of pointers.
1) its easier to remove the tb off the manifold instead of keeping it on there.
2) its not necessary to replace the gaskets except possibly the tb if it is rip. the manifold gasket is metal so unless its truly warped dont replace it.
Carlo
Old Jul 25, 2009 | 01:44 AM
r2kay's Avatar
hey guys, new to this.....carlo whats 'tb'?
Also can I change the knock sensor wire without removing the intake manifold?
Old Jul 25, 2009 | 11:51 AM
1fsthatch's Avatar
Tb (throttle body)
Old Jul 26, 2009 | 11:15 PM
240sx acura tech's Avatar
acura master tech
if your replacing the wire . just remove the p/s pump and you can get your hand in there . with removing the belt and the pump and replaced the wire it will take 30 mins
tops. i do them all the time.
Old Aug 8, 2009 | 12:26 PM
tiger7155's Avatar
Carlo/anybody:
I have a '02 TL. The dealer said I have a bad knock sensor. Do you have a pdf drawing or replacement procedure for this job? I want to replace it by myself.
Thank you a lot!
Tony
Old Aug 8, 2009 | 12:41 PM
Ron A's Avatar
Administrator
Welcome to the forums. It's in the 3G Garage
A-013: n: Knock sensor wire chewed by a mouse
https://acurazine.com/forums/showthread.php?t=86162
https://acurazine.com/forums/car-parts-sale-361/2000-tl-forsale-173982/ DIY
RobbDizzle
Oct 15, 2015 11:16 AM
thegipper
Sep 28, 2015 01:01 PM
hrothgar02
Sep 28, 2015 11:08 AM
prbori
Sep 27, 2015 01:37 AM
STL TL-S
Sep 23, 2015 08:52 PM
