Knock Sensor
Knock Sensor
Does anyone have any idea on how to replace a Knock Sensor on a 2005 Acura TL? I would rather take a whole Saturday to get it done instead of paying 501.92 to have it done at the Acura Dealership.
whats your email. i'll send you the pdf pages for the job. its an easy job. if you are mechanically inclined. i just replaced mine over the weekend due to the rat chewing the wire out.
couple of pointers.
1) its easier to remove the tb off the manifold instead of keeping it on there.
2) its not necessary to replace the gaskets except possibly the tb if it is rip. the manifold gasket is metal so unless its truly warped dont replace it.
Carlo
couple of pointers.
Carlo
acura master tech
if your replacing the wire . just remove the p/s pump and you can get your hand in there . with removing the belt and the pump and replaced the wire it will take 30 mins
tops. i do them all the time.
Carlo/anybody:
I have a '02 TL. The dealer said I have a bad knock sensor. Do you have a pdf drawing or replacement procedure for this job? I want to replace it by myself.
Thank you a lot!
Tony
Thank you a lot!
Tony
Welcome to the forums. It's in the 3G Garage
A-013: n: Knock sensor wire chewed by a mouse
https://acurazine.com/forums/showthread.php?t=86162
https://acurazine.com/forums/car-parts-sale-361/2000-tl-forsale-173982/ DIY
STL TL-S
09-23-2015 08:52 PM
