Keyless memory help
Old May 28, 2010 | 03:30 AM
rt0rresjr's Avatar
Keyless memory help
Ok so I just bought my 3g TL and had to replace the old keyless remote. I tried programming the keyless remote by doing the lock in the ignition switch 4 times. I also tried linking the remote by holding the lock and unlock til the LED blinks, and still my keyless remote setting says "unable to customize setting". Can someone please help me step by step on how to figure this out.
Thanks in advance,
Old May 28, 2010 | 12:59 PM
rt0rresjr's Avatar
I also forgot to mention that my remote is able to lock, unlock, panic and open the trunk. The only problem is that it wont let me customize my keyless remote setting
Old May 28, 2010 | 04:57 PM
guitarplayer16's Avatar
Does your MID show "Driver 1 Detected" or "Driver 2 Detected" when you enter the car with the corresponding remote?
If no, you'll have to pair your memory settings.
It shows you how to do this on the back of the remote.
Press lock and unlock at the same time to pair your memory settings.
Old May 29, 2010 | 12:07 AM
rt0rresjr's Avatar
thanks alot
Old May 31, 2010 | 07:20 AM
wozniecki's Avatar
i just get a remote from ebay now i have 2 remotes i programmed the remotes are working good (lock and unlock trunk etc) but the second remote do not show driver 2 detected !why? anything i can do?
Old May 31, 2010 | 03:23 PM
Did you try the method I posted above?
Old Jun 1, 2010 | 05:55 AM
wozniecki's Avatar
yes, i try but when a push the lock and unlock at the same time no red light only when i push one bottom for lock or unlock only one remote is paried with the car the second remote only works for lock ,trunk , panic, etc
PD: i have only one key .
Old Jun 1, 2010 | 06:19 AM
Did you buy a "Memory 2" remote?
I have a feeling you have two "Memory 1" remotes.
Old Jun 1, 2010 | 10:33 AM
wozniecki's Avatar
how can i check that maybe you are right!!!
Old Jun 1, 2010 | 04:44 PM
It should say on the back of the remote "Driver 1" or "Driver 2" unless it's worn out.
Try pairing the remote again, except press and HOLD the lock and unlock buttons UNTIL you see TWO blinks.
The two blinks indicates that the remote is linked to the memory seat.
Old Jun 1, 2010 | 05:56 PM
wozniecki's Avatar
You aré right i got the remote control no name one saya driver 1 and the second just few numbers i have to order again , and also the module assy under my driver seat cuz the memory of my seat is not working i dont thing is the door panel boton i check all fuse and is ok
Old Jun 2, 2010 | 09:13 PM
I'd have a dealer check that out
Old Jun 11, 2010 | 05:55 AM
wozniecki's Avatar
well today i got my remote control memory 2 ! works great also i see one thing when you press the bottom unlock 3 times the last one you hold all windows and sunroff go open is that ok? !
Old Jun 11, 2010 | 06:27 AM
Glad to hear it works!
Yes, if you press and hold the second time, the windows and sunroof go down to as much as you hold it.
Nifty feature for the summer time =)
Old Jun 11, 2010 | 10:56 AM
wozniecki's Avatar
exelent! and it goes up also? ;-)
Old Jun 11, 2010 | 08:04 PM
Unfortunately, no.
You would have to have a module installed so that they can roll up holding the lock button.
https://acurazine.com/forums/3g-tl-2004-2008-93/kp-technologies-window-roll-up-module-install-3g-garage-i-097-a-596643/
Alternatively, you can just use your keys to roll up the windows so you don't have to get inside your car.
Just put the key in the door, lock it once (turn key to left), then lock it again and hold it.
Cool features! =)
Old Jun 12, 2010 | 08:38 AM
wozniecki's Avatar
Sweetttttttttttttttttttttt!!!!!!!
Old May 16, 2013 | 01:11 PM
NEWGIRL's Avatar
okay I've only had my '07 acura tl for a few months and just realized the dealer only gave me remote 2...I saw a lot of posts saying they can be bought on ebay so my question is what do i search and what do after i buy it?
Jul 16, 2017 07:33 AM
nj2pa2nc
Aug 19, 2016 06:18 AM
ceb
ILX
Sep 27, 2015 10:56 AM
GraveDigger
Sep 18, 2015 07:46 AM
