It's getting cold outside, my heater doesn't work
Old Sep 16, 2012 | 01:28 AM
pnokio's Avatar
Hi,
I have a base 2005 at
I'm wondering what's wrong with my hot air, fan is still working but no hot air is coming out, even at HI, it's still a normal cold...My ac does work properly. Engine cold or hot, still no hot air...I don't miss coolant liquid. No check engine. Any answer to that?
Thank you
Old Sep 16, 2012 | 06:05 AM
Turbonut's Avatar
Check to see if the heater control valve cable is attached, or bad heater control valve.
Old Sep 21, 2012 | 08:37 PM
pnokio's Avatar
Where can I find that cable?
Old Sep 21, 2012 | 10:15 PM
ZOMGVTEK's Avatar
The water valve is near the passenger side firewall, under the hood. The water valve will of course need to be open for coolant to flow into the heater core inside the cabin, which is what the fan blows air past to heat the cabin. If no coolant flows into the heater core, you're not going to get heat. The valve is likely stuck closed or otherwise damaged, otherwise you have a clogged heater core or seriously low coolant.
It's easy enough to find, it has smaller coolant lines running to it, and sits on the firewall.
Old Sep 21, 2012 | 10:23 PM
pnokio's Avatar
Thank you, I look at this tomorow
Old Sep 21, 2012 | 10:35 PM
pnokio's Avatar
I change my suspension and play with the oem strut bar, are they close? Might be the cause?
Thanx
Old Sep 21, 2012 | 10:56 PM
pnokio's Avatar
https://acurazine.com/forums/3g-tl-2004-2008-93/f-167-heater-water-coolant-control-valve-diy-747304/
Is it what I should do?
Old Sep 21, 2012 | 10:58 PM
SpiderX1016's Avatar
Sorry but I have to say. It's getting cold out? Where do you live? It's still high 80F around here
https://acurazine.com/forums/showthread.php?t=747304
Look at where the heater valve is. Give it a visual inspection and then have someone turn it from cold to hot and back to cold. Watch to see if the cable/valve moves.
Old Sep 22, 2012 | 01:20 AM
pnokio's Avatar
I live in Montreal, Canada
Old Sep 22, 2012 | 11:10 AM
pnokio's Avatar
Okay, I just find what it is, heater control valve (open close section is broken), cable does work when I'm turning on the temp, but they are not attached...
Thank you
Old Sep 26, 2012 | 03:31 PM
pnokio's Avatar
Fix it it was the heater control valve that were broken... Bought the part from honda for 27$ CAN ... Acura sell for 32$CAN.. And yeah it's hotter than before and hcv come with bracket
Thank you
AndrewS
19
Mar 14, 2024 06:59 PM
acurajj
Sep 19, 2015 03:47 PM
EE4Life
Sep 11, 2015 10:13 PM
04tler
Sep 10, 2015 01:13 PM
dlknight
Sep 3, 2015 07:54 PM
