Intermittent misfire
Old Jul 9, 2015 | 11:00 PM
Pazzo1's Avatar
Well looking for some advise. Seems my car has an intermittent misfire. While driving to work tonight, I accelerate from the lights and hear two muffled pops and CEL comes on than the motor is running smooth as silk. I had a misfire code about 3 months ago as well so I changed all the plugs and 1 coil pack but never heard the popping sound before.
How I wish I had my scanner rite now...lol
Old Jul 10, 2015 | 04:57 AM
csmeance's Avatar
check all your spark plugs and make sure they are tight! The J-series is known to loosen spark plugs over time and make them eject!
Go to autozone and you can get a scanner and see which cylinders it was on. How many miles on the car? Premium fuel? how hard were you accelerating?
The pop could have been backfire from unburnt fuel in the exhaust. I would run a fuel cleaner like redline SI-1 or Chevron techron and see if it helps before throwing parts at the problem.
Once you know which cylinders are misfiring, move the coils around and see if the problem moves with the coil or stays at the same cylinder/s
Old Jul 10, 2015 | 06:50 AM
Pazzo1's Avatar
Just waiting to get home and hook it up to the scanner. If it comes up cylinder #1, I'm thinking the coil might be gone because that's the reason I changed the plugs originally. Just hoping not an injector going bad.
Old Jul 10, 2015 | 09:39 AM
Pazzo1's Avatar
Well scanned the car, misfire cylinder #1 again. Thinking the new coil I bought is junk. Well I'll move it to another cylinder tonight and see what happens.
I've always run Shell V power( no ethanol) and it only has 167,000 Km.
Old Jul 15, 2015 | 07:53 PM
csmeance's Avatar
When were the spark plugs replaced? Move the coil over to the other bank of cylinders and report back. I'd take out the #5 coil and spark plug and swap both over to #1
Old Jul 17, 2015 | 10:42 PM
I hate cars's Avatar
If it does it more under heavy load once hot, it's probably ignition, especially a coil. If it does it most at idle it's likely a mechanical issue like low compression.
If the pop is through the intake it's likely a lean condition. Just one cylinder misfire would point to an injector. All cylinders misfiring would be pump or regulator.
You don't need to move the coil to the other bank. Just move it to the easiest to get to.
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
kencepeda
Sep 26, 2015 05:13 PM
Brandle34
Sep 23, 2015 07:20 PM
rklatzkin
Sep 23, 2015 04:08 PM
wb2ee
2G RDX Problems & Fixes
Sep 22, 2015 12:00 AM
