Instrument panel not working in the cold
Old Jan 26, 2007 | 07:38 AM
richard1225's Avatar
has anybody experienced a problem with the intrument panel not working when it has gotten really cold? all the lights are out the rpm, speedometer, fuel guage, and temp guage all not working. the only lights that come up are vsa, abs, and brake.
Old Jan 26, 2007 | 07:49 AM
SSMTL04's Avatar
Team SSM
hmmm nope...but I see your from Brighton....it's frezzzzzzzzzzzzzzzzzzzzzing this morning!!!!!!!!!!!
Old Jan 26, 2007 | 08:52 PM
JohnDoe2's Avatar
You wouldn't happen to have them dimmed way down would you?
Old Jan 26, 2007 | 08:54 PM
SteveP66's Avatar
Kaa - Ching !!!
From: Rhode Island.....Self-Proclaimed Chromed Cousin of Brettallica
I noticed it more on the radio panel this morning and the MID.......but not the rest of the gages......
could be that it was 8 degrees when I went to work this morning
Old Jan 26, 2007 | 09:47 PM
Eoanou's Avatar
'10 Hyundai Genesis Coupe
The only thing I notice in the extreme cold is that when flipping through the different selections on the MID it does it slowly, by that I mean when you go from Trip Computer to Odometer you notice Trip Computer slowly fading out and the Odometer readings slowly fading in.
It's nothing huge, nothing you wouldn't expect either.
Old Jan 26, 2007 | 10:41 PM
MTVtec's Avatar
Got VTEC?
You mean nothing was working? Every thing was black or was it dim? Could be that you dimmed every thing by accident, as mentioned earlier.
Matt
Old Jan 27, 2007 | 03:11 AM
leedogg's Avatar
RAR
and does it go back to working normal when it warms up? if not, maybe check fuses.
Old Jan 27, 2007 | 03:50 AM
neuronbob's Avatar
Never had this issue with my TL in the cold. Check fuses, check illumination level, if neither helps, time for a dealer visit.
Old Jan 27, 2007 | 04:45 PM
MatterofTime's Avatar
Agree, I notice the same thing in the cold weather in Albany, NY. -15 degree windchill is not whats good in da streets up here.
Old Jan 28, 2007 | 09:58 AM
tehloxely's Avatar
I noticed that my rear view auto dim doesn't work in the cold.
Old Jan 28, 2007 | 10:34 AM
SteveP66's Avatar
Kaa - Ching !!!
Let's clarify - it's not that things were not working - they were just dim and slow in responding.........this used to happen on my 03 Accord as well. As soon as the cabin warms up a bit it goes back to normal. I don't think it's anything to worry about - has something to do with the digital display and very cold temps
Old Feb 3, 2007 | 03:04 PM
GTACURA's Avatar
I have experienced that same problem but my car started with no problem everything was functioning. Then i stop get coffee and the the RPM, Fuel Gauge is totally not working but then everything else is functioning properly im in NJ and it was pretty cold this morning Im going to check the fuses but this is weird
Old Feb 5, 2007 | 04:11 PM
tehloxely's Avatar
It doesn't turn on at all. Even if I've been in the warm warm car for over 2 hours. I'm just going to call Acura anyways.
Old Feb 6, 2007 | 09:40 AM
GTACURA's Avatar
Took mine to the dealer yesterday they said it was just a blown fuse (Thank God) no charge
Check your fuses
Old Dec 20, 2010 | 09:19 AM
MattT1452's Avatar
9th Gear
Has anyone solved this problem? I have a 2007 TL and having the same issue when it's below 30° F outside. The lights will flash and gauges will work and fall every few seconds until the engine warms up (about 5 minutes). The radio and clock display also will turn off and on with the instrument panel, yet the radio will still play sound. It's quite frustrating and would like my car to work when I drive it.
I took the problem to the dealer and they cannot figure out the issue. They replaced the battery, replaced the computer and it is still acting up. I am taking it down for the 3rd time to have them look at it. Acura said all voltage readings and fuses look good. Any direction of help would be appreciated.
Old Dec 20, 2010 | 07:50 PM
mrceotri's Avatar
i have a similar issue but with the Navi screen. It would be really dark to see, but after i let the screen warm up it brightens to full potential. took it to the dealer and they told me its normal for that to happen in the cold. I disagree.
I'm not sure about your situation thought, but please update when you have found a solution.
Old Dec 20, 2010 | 08:46 PM
MattT1452's Avatar
9th Gear
Here is a video of what the car does every morning when I start it. The colder the weather, the worse it is.
http://www.youtube.com/watch?v=3PROVY8SjyQ
Old Jan 4, 2011 | 06:29 PM
MattT1452's Avatar
9th Gear
Issue has been resolved. A new 'gauge control module' (aka instrument panel) was installed into the car as well as a new fuse relay box located under the dash. All this was covered under my certified warranty. Had a hard time finding the problem, but glad the car is fixed!
Old Jan 29, 2011 | 11:08 AM
plonka's Avatar
4th Gear
I'm trying to figure a gauge problem for my boss. She has an 07 TL 3.2. Her gauges guit working altogether, they illuminate, none of the needles work, they all rest at empty, cold, 0mph, 0rpm etc... while she's driving. Any ideas?
Old Jan 29, 2011 | 04:41 PM
Turbonut's Avatar
Sorry, but you already have one thread started concerning the problem, why open another?
Old Jan 29, 2011 | 07:50 PM
plonka's Avatar
4th Gear
This is the link that you referred me to, I thought I could get more info about my problem.
Old Jan 23, 2012 | 05:12 PM
m_wrx's Avatar
i am having the exact same problem..has anyone figured anything out..i have the same problem as "plonka" nothing works doesnt matter if its cold or hot
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
acurajj
Sep 19, 2015 03:47 PM
dlknight
Sep 3, 2015 07:54 PM
