Instrument gauges, blinkers and windows not working
Old Aug 8, 2013 | 05:23 AM
scotian84's Avatar
7th Gear
Hi i have an 06 tl and i change my deck over and now my instrument gauges blinkers and windows wont work anymore i tried hooking up the old deck and still the same problem so it aint that. Does anybody have a clue what is wrong with this? Thank you
Old Aug 10, 2013 | 05:03 PM
iheartteal's Avatar
what are you referring to as a deck
Old Aug 10, 2013 | 06:00 PM
dannyz's Avatar
TLicious Type S
It's pretty clear that you unplugged or severed a power connection (or ground) somewhere. I suggest going back over your work, and looking at every wire you touched, and putting them all back the way they were.
Old Aug 10, 2013 | 09:50 PM
MarcoNorthPolo's Avatar
KCCO
Exactly.
Old Jul 17, 2019 | 12:57 AM
Heatherenea's Avatar
7th Gear
Same Problem!!
What did u do to solve this? I have an '04 TL. Removed the stereo, then put it all back in. Now I have no gauges, no windows, no blinkers.
Hazards work & windows still work with the key/ door locks.
Also, the A/C compressor doesn't kick on anymore either.
PLEASE HELP!
Old Jul 17, 2019 | 03:46 PM
PLEASE HELP!
You blew a fuse
Old Jul 17, 2019 | 07:02 PM
7th Gear
Is there a hidden fuse somewhere? Because I have individually checked every single one. Not to mention that each window is on its own separate fuse as well as the wipers ect... They are all fine.
Windows still work with the key in the door & the hazards work, but no blinkers. No dash lights. & None of the gauges move at all.
Old Nov 15, 2024 | 07:25 PM
Clear0's Avatar
I'm having the same problem. Help!
I am having the SAME problem! Did you ever figure out what happened? I put a radio in. I hooked up the illumination wire to the lights on signal wire. Now I have no gauges, no dash lights, no blinkers, no wipers, no windows, won't shift out of park (have to use the shift lock button)
Old Nov 15, 2024 | 11:44 PM
Pair of TLs's Avatar
Originally Posted by dannyz
it's pretty clear that you unplugged or severed a power connection (or ground) somewhere. I suggest going back over your work, and looking at every wire you touched, and putting them all back the way they were.
+1
Feb 25, 2020 09:57 AM
TLDude876
Dec 28, 2016 03:18 PM
acurajj
Sep 19, 2015 03:47 PM
ahsm
Sep 9, 2015 08:35 AM
