Installing the damper... Help
Help... I just installed the damper and found that there is a small little bracket with a welded bolt on it. This bracket hits the plastic guard. Should I be cutting that off?
AZ Community Team
Received 7,771 Likes
What damper? What bracket?
Got pics????
A little clarity goes a long way.
Ya. Guess that would have helped. I just cut it off. The damper I was referring to is the one that "eliminates" the vibration at 1,600 rpm. Seems to have worked. We'll see tomorrow.
How did installing the damper work out for you and how is it holding up? And is your car a 6spd?
This is the service bulletin I was referring to: http://www.in.honda.com/Rjanisis/pubs/SB/B05-017.PDF
cycdaniel
12-17-2019 10:58 AM
pistacio
09-26-2015 09:45 AM
