Installing the damper... Help
Old Nov 14, 2009 | 02:11 PM
BMelch's Avatar
9th Gear
Help... I just installed the damper and found that there is a small little bracket with a welded bolt on it. This bracket hits the plastic guard. Should I be cutting that off?
Old Nov 14, 2009 | 06:44 PM
Bearcat94's Avatar
AZ Community Team
What damper? What bracket?
Got pics????
A little clarity goes a long way.
Old Nov 14, 2009 | 08:10 PM
BMelch's Avatar
9th Gear
Ya. Guess that would have helped. I just cut it off. The damper I was referring to is the one that "eliminates" the vibration at 1,600 rpm. Seems to have worked. We'll see tomorrow.
Old Nov 15, 2009 | 08:30 AM
brimp's Avatar
Nice to hear, let us know if it worked. Did you get the damper at a dealer or online? How much?
Old Apr 14, 2010 | 09:42 AM
mc_holla's Avatar
How did installing the damper work out for you and how is it holding up? And is your car a 6spd?
Old Apr 14, 2010 | 10:43 AM
kplatuli's Avatar
Were you following the directions on the TSB for the dynamic damper, and the directions did not address the tab? I am going to be installing the same thing this weekend.
Old Apr 14, 2010 | 10:44 AM
kplatuli's Avatar
This is the service bulletin I was referring to: http://www.in.honda.com/Rjanisis/pubs/SB/B05-017.PDF
Old Apr 14, 2010 | 11:37 AM
RACINGHART03's Avatar
I have installed a few of those and I dont remember having to cut anything???
Old Apr 14, 2010 | 11:40 AM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
Resurrection. But still curious...
Old Apr 14, 2010 | 12:32 PM
mc_holla's Avatar
Based on your experience with these dampers, how effective would you say they are?
cycdaniel
Dec 17, 2019 10:58 AM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
pistacio
Sep 26, 2015 09:45 AM
TxRzrBk
Sep 17, 2015 01:07 PM
