Inspire fogs
Old Sep 2, 2014 | 11:00 AM
.TODD's Avatar
Inspire fogs
just installed inspire fogs when I turn them off the button stay lit.im not sure if this will be enough draw to kill the battery or not? will the battery die even tho the lights them selves are off?
Old Sep 2, 2014 | 10:48 PM
rockyfeller's Avatar
King of NYC
It depends. If you have a brand new battery and you use your car several times a day, it's not gonna die from something so small.
But why risk it? Even though it is a small draw, it is still constantly draining power for no reason. How long do you think it will be before it does inevitably die from a preventable cause? Why wonder?
The point is that it shouldn't be on of course, so it's better to fix it.
Old Sep 3, 2014 | 08:03 AM
.TODD's Avatar
good point. wHats a 12 volt switch wire I can tap into for power when you hit the switch. preferably under the hood since I already have a wire that's running there and its easier rather than take apart the bottom again.?
Old Sep 3, 2014 | 08:05 AM
TLDude876's Avatar
Chapter Leader (Houston)
The wiper motor wire
Old Sep 3, 2014 | 09:37 AM
.TODD's Avatar
that at the base of the wiper?
Old Sep 3, 2014 | 09:39 AM
guitarplayer16's Avatar
use fuse #32 with add-a-fuse
same thing as wiper motor wire, but way easier
Old Sep 3, 2014 | 02:34 PM
.TODD's Avatar
wait..what? run the line into the fuse box? might look a little tacky
Old Sep 3, 2014 | 08:22 PM
Fuse #32 is in the cabin.
You can't see anything behind all the plastic covers.
Splicing into the wiper motor wire looks more tacky.
Old Sep 4, 2014 | 10:36 AM
.TODD's Avatar
so run the wire straight into fuse 32? that's it?
Old Sep 4, 2014 | 10:46 AM
Yes, Fuse #32 is hot when you turn your car on.
Right now, your wire is hot 24/7, because you're wired to a constant 12V source.
Old Sep 4, 2014 | 10:53 AM
.TODD's Avatar
gonna add a fuse it like you said see if I can find one at autozone thanks?
Old Sep 5, 2014 | 07:52 AM
.TODD's Avatar
done. thanks bro put it in 32
ITSJESTER
4G TL Photograph Gallery
Oct 13, 2015 12:53 PM
Avenger411
Oct 11, 2015 03:53 PM
rockyboy
Sep 29, 2015 12:05 AM
rhdune16
Sep 28, 2015 11:31 AM
Dman00tl
2G TL Photograph Gallery
Sep 25, 2015 10:34 AM
