Inside trunk open button wont work .. Help?
The obstacle is the path.
the button inside my car to pop the trunk open won't work anymore.. anyway i can fix this myself. Oh i drive a 2007 tl type s.
thanks
thanks
I am having the same issue on my 04 TL. I have tried opening the trunk with the inside button with the switch in the glove box flipped either way. Does not open. You may want to also check the connections behind the switch in the glove box and the trunk button on the drivers side. Mine are both connected but still it won't open. Have you resolved the issue?
I'm having a similar set of trunk problems with my 06 TL; take a look at the followng thread for all of the gory and unhappy details.
Oh how I wish my problem had been resolved with the $60 trunk latch assembly
https://acurazine.com/forums/3g-tl-problems-fixes-114/2006-tl-navi-trunk-lid-wont-open-758591/
I disconnected the battery of the car for 45 minutes to try to reset the MICU and you guys will not believe it but the %$%$#% trunk opener button worked for about ten minutes but stopped working about the time the nav system completed the power on alignment after restoring battery power
Wish I had a trunk with a key.
I have the trunk opener on my keys, but that is the only method that works. It can be a pain at times because the car must be off for this button to work.
neither way works for me, I just ordered to detailed electrical manual so I can troubleshoot the harnesses. All my switch test fine and it looks like the problem is in the MICU. I'm going to try to jump the harness around the MICU so at least the inside button will work.
Wonder if Advanced Auto Parts can check the codes for me to confirm the MICU is bad
Team SSM Queen
This happened to me once because my trunk was loaded and something was blocking the latch, preventing it from popping. If it's as simple as that, you can just open the pass-through and pull the little ring to manually open the trunk.
Did you get your problem with the inside trunk switch resolved? My inside switch also just stopped working. I can still open it up with the remote though. I just replaced the bulbs in the inside switch two days ago, wonder if that has anything to do with it. Maybe the switch has gone bad?
I have the same problem. My trunk bottom wont open the trunk and its unlocked from the glove box... But it open with the alarm remote... I read everything but i didnt get what u guys said about the bulb.. What exactly i have to do to fix that?
Please help i will appreciate that
Ahh...another old thread bumped.
mada51589
05-03-2022 08:54 PM
brandnewcolony
09-12-2015 10:39 AM
