Humming noise in 5th gear AT tranny
Old Jul 30, 2012 | 02:36 AM
KidChenz89's Avatar
05 SSM
I've notice recently I'm getting this humming/drone noise whenever the car is in 5th gear. The noise starts around 60mph+ either I'm accelerating or letting off the gas the sound is still there. But when I down shift to 4th the noise goes away. Has anyone here had this problem before ?
Old Aug 2, 2012 | 11:53 AM
LoveMyTL-S's Avatar
Anyone.....??
Old Aug 2, 2012 | 12:58 PM
SharksBreath's Avatar
BANNED
seems whenever i hit 5th gear in mine, the drone is increased on my exhaust. it's normal.
like you'll be cruising along in 4th gear in SS and then switch to 5th and the rpm's drop and the exhaust goes "bbbbbmmmm". <-that's my impression.
Old Aug 2, 2012 | 07:58 PM
YeuEmMaiMai's Avatar
check your wheel bearings
Old Aug 3, 2012 | 08:20 PM
Roger555's Avatar
OCD
Could be a differential whine however once you get a whine its too late! Whats the service interval for the differential fluid? I have a manual not familiar
Old Aug 3, 2012 | 09:54 PM
^ differential is intergrated into the trans and as such uses auto trans fluid for lubrication.
Old Aug 3, 2012 | 10:06 PM
Roger555's Avatar
OCD
Really ? I guess they changed it probably in 04 then the transmissions started failing what about the tranny fluid then, I don't even see a mileage in your post! common OP.
Old Aug 4, 2012 | 04:03 PM
fat_tire's Avatar
8th Gear
Here's what I would check:
Service Bulletin 05-017
Engine Mounts
Transmission Mounts
I'm having the same problem. Doing the 105k check this month some time and replacing the timing belt/pump, tensioner, spark plugs, transmission pressure switches, and 1x3 red line ATF. If this doesn't fix it, I don't know WTF will.
Old Aug 4, 2012 | 04:05 PM
fat_tire's Avatar
8th Gear
Also, something I have not tried yet is to neutralize your motor mounts. (Mine is more of a vibration than a sound).
Old Aug 11, 2012 | 01:40 AM
KidChenz89's Avatar
05 SSM
Engine Mounts
Transmission Mounts
I have solid mounts on mine but that shouldn't be the problem had that done 10k ago.. and just did a 3x3 ATF / switches / filter 2k ago..
I dont think this have anything to do with the tranny since the sound does get a bit higher when the car is about 65mph @1.5k-1k in neutral. I might have a leak somewhere, ill check the bearings also. ill keep you guys updated she sitting at 125k right now.
4drviper
Apr 23, 2025 07:13 PM
Pham Alvan
May 18, 2021 06:48 AM
SidhuSaaB
May 30, 2020 12:40 AM
Charles Bennett
Jan 28, 2018 08:53 PM
joflewbyu2
Oct 8, 2015 11:16 AM
