How replace molding by door handle.... HELP
Old May 20, 2008 | 11:11 PM
riplee's Avatar
AMFTW
I've done some research but have come up empty, other threads did not have
images to show problem so I'm hoping in doing so will get this problem solved.
I do know that the door panel has to be taken of.. correct? If so above is my current
progress. I've taken off 4 screws. I need to know if there are any others hidden that
need to be removed, if not do i now pop it off? Is there any difficulty putting
everything back together again or is it fairly simple? Any advice from similar
experiences would be greatly appreciated. I do have the replacement part with the
molding and the base. Just need access to unscrew old base and replace with new
part
Old May 21, 2008 | 12:20 AM
Bearcat94's Avatar
AZ Community Team
What are you trying to do?
Just replace that peice that is missing in the first pic?
If so, just get a new one and pop it on. ~$10. There is actually a TSB for this and the dealer might do it gratis. No need to go fooling with the door panel or extra screws or whatever.
If you're talking about removing/shaving the door handles, that is something else entirerly.
Try These:
E-022: DIY: Driver side door lock MOD
https://acurazine.com/forums/showthread.php?t=82775
https://acurazine.com/forums/audio-video-electronics-navigation-22/quick-question-aftermarket-hu-125597/
F-016: DIY: Front/rear door panel/handles/wstrip/glass/window regulator removal
https://acurazine.com/forums/car-talk-5/my-car-super-street-143797/
https://acurazine.com/forums/ramblings-12/trance-list-93985/
Old May 21, 2008 | 12:40 AM
riplee's Avatar
AMFTW
Try These:
https://acurazine.com/forums/showthread.php?t=125597
https://acurazine.com/forums/showthread.php?t=143797
https://acurazine.com/forums/showthread.php?t=93985
Yes I'm trying to replace that piece in the 1st & 2nd pic, it fell off when i drove home from work. I did try to snap the molding piece on but the base part (ugly metal thing) won't grasp the molding correctly and does not stay on. The base needs to be replaced as well so thats why i'm asking about how to get into the door. thx
Old May 21, 2008 | 08:24 AM
vinnier6's Avatar
stop what you are doing, button everything back up....visit your local dealer and they should fix it for free...there is a tsb on this....otherwise, you can get a new one already painted and it will just pop on ....there is no need to unscrew anything from the inside of the car for the outer door handles....
Old May 21, 2008 | 10:08 AM
don5504's Avatar
You seem to be in good hands with these 2 guys already.
D
Old May 21, 2008 | 10:12 AM
jrican1219's Avatar
so that is why my dealer ordered one for free even though i am out of warrenty... makes sense now!
Old May 21, 2008 | 11:06 AM
vinnier6's Avatar
correct....its like a 5 dollar piece...some folks take the drivers one off and put the other one on so as to not have a key hole....
Old Jun 18, 2008 | 03:12 PM
ddf_05tl's Avatar
The one on my 05 just fell off this weekend. Do I need the TSB to get them to replace it? If so where can I find it?
Old Jun 18, 2008 | 08:30 PM
Bearcat94's Avatar
AZ Community Team
https://acurazine.com/forums/showthread.php?t=154245
TSB 07-043
Old Jun 19, 2008 | 02:29 PM
ddf_05tl's Avatar
thank you very much
Old Mar 20, 2014 | 03:42 PM
joconnor54's Avatar
5th Gear
When I try and look at the TSB 07-043 I get this message:
You are not authorized to view the content on this page.
If you believe you have received this message in error, please contact the Support Center.
Please go back or return to the home page.
Old Mar 20, 2014 | 06:41 PM
Ron A's Avatar
Administrator
Welcome to the forums.
I just tested the bulletin and it opens for me.
You have to follow the instructions exactly as they are posted, including clearing your cache if you are using Firefox and probably some other sites.
https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-technical-service-bulletins-tsbs-3g-garage-j-016-a-613659/
Old Mar 21, 2014 | 10:22 AM
joconnor54's Avatar
5th Gear
Thanks, I did clear my cache on Firefox, I will try a different browser
Old May 11, 2014 | 11:20 PM
EM2typeflex's Avatar
Try These:
My TL is missing all 4 door handle caps. Thanks for this informative post, now I'm going to go to the dealer and see if I'm able to get them free, or just pay the $12 each for them because little things like that drive me crazy.
rockyboy
Aug 4, 2024 10:35 AM
tman570
Jun 11, 2019 07:56 AM
EE4Life
Sep 11, 2015 10:13 PM
michaellong77
1G CL Problems & Fixes
Sep 11, 2015 12:54 AM
Steven Vitek
ILX
Sep 10, 2015 07:29 AM
