How to remove carpet?
Old Jun 10, 2011 | 05:01 PM
nsxxtreme's Avatar
Is there any video or tips on how to remove the carpet.
The previous owner of my car was a pig and the carpet is really dirty. I want to remove it so I can pressure wash it.
I know the seats need to be removed. I have removed the fronts already which is no problem. I need to know how to get the side door sils (sp?) off and how to remove the rear seat. Also does the center consule need to be removed?
Old Jun 10, 2011 | 05:19 PM
04WDPSeDaN's Avatar
iWhine S/C 6MT TL
Remove both front seats, center console, dead pedal, rear lower seat only and all plastic trims that run along the carpets.
Old Jun 13, 2011 | 10:05 AM
Negative1's Avatar
+1
It'll take a while, but take your time and it'll come out. Once you get the everything out of the way, fold the front (carpet near the pedals) over the middle (where the seats were) and fold the rear carpet over the middle; that makes it much easier to pull out from the front doors.
Old Jun 13, 2011 | 10:09 AM
Negative1's Avatar
Also, I suggest using Simple Green and a scrub brush. Pressure wash the carpet to get the loose stuff off, then use a liberal amount of simple green and scrub it a lot. You may have to "rinse and scrub" a few times to get it clean. This usually takes a while, so I would start as early in the morning as you can.
Old Jun 13, 2011 | 11:30 AM
nsxxtreme's Avatar
I got the carpet out. The carpet goes under the shifter and under the ebrake. I just cut the carpet at those locations. You also have to pull it over the gas pedal. For that I just removed the pin and slid it over the top of the pedal.
Carpet came out WAAAYYYY cleaner after pressure washing. Almost looks new again.
Old Jun 15, 2011 | 08:59 AM
invalidalias's Avatar
congrats dude!! good idea on the gas pedal issue. cutting the carpet from the middle console is easiest too
Old Dec 24, 2012 | 08:45 AM
AcNoob's Avatar
Should i be concerned with taking out the seats with side airbags? Is there any risk of them exploding or do I have to reset any thing?
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
CL-S progression 01
Jan 26, 2016 04:15 PM
dainmezron
Oct 16, 2015 06:56 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
lowgrowl
Sep 26, 2015 05:18 PM
