How to remove brembo calipers
Old Apr 29, 2009 | 12:57 PM
bdogg77's Avatar
Can someone please tell me how to take off the brembo calipers/tools needed on 04 6MT TL. I tried to search but found nothing. I am trying to install new Rotora rotors/pads. Any help would be greatly appreciated.
Old Apr 29, 2009 | 01:47 PM
Turbonut's Avatar
These might help:
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/diy-2007-tl-s-brake-pad-replacement-629428/
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/3g-garage-d-094-brembo-hawk-pad-replacement-w-pics-579140/
Old Apr 29, 2009 | 02:13 PM
Bearcat94's Avatar
AZ Community Team
And Service Manual Scans Here:
D-041: Brakes-front/rear caliper overhaul, front/rear pad replacement, brake bleeding, brake disc specifications, parking brake adjustment
https://acurazine.com/forums/showthread.php?t=118283
D-085: Brake disc (rotor), knuckle, hub, and front wheel bearing replacement
https://acurazine.com/forums/religion-politics-18/world-opinion-132940/
Basically there is a brake line support on the steering arm, then 2 big bolts on the back side of the caliper. NOT the allen bolts (those hold the caliper together), but the Hex Bolts that mount the Caliper to the knuckles.
Old May 1, 2009 | 08:53 PM
bdogg77's Avatar
Turbonut/Bearcat94, thanks for your help. Well being that i am so impatient, i just took my time and figured it out. those 2 bolts were a PITA. I couldn't get them off w/ my socket wrench, so i thought i would see if my tire tool would work......it did! I used my jack stand rails as a breaker bar and it worked beautifully. Just thought i would share this tip as it worked very well. Thanks again for the help.
Jul 16, 2017 07:33 AM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
polish_pat
Sep 30, 2015 12:22 PM
2ManyHobbies
Sep 24, 2015 09:23 PM
