Horrid sound please help !!!!!
Old Apr 5, 2018 | 08:38 PM
Jrad96TL's Avatar
Old Apr 5, 2018 | 08:58 PM
Jackass's Avatar
Where is the sound coming from? Is it RPM specific? Where there any other symptoms? Did it just happen out of the blue? Need more context to give a proper reply.
Old Apr 5, 2018 | 09:36 PM
Jrad96TL's Avatar
No it is not rpm specific it’s there as long as the engine is running. I literally went in to the store came out and the sound was there. It sounds like it’s coming from the area right where the egr is
Old Apr 5, 2018 | 09:48 PM
Pair of TLs's Avatar
Cool EGR sound?
Sounds like sucking big air--like the EGR/hose connection broke or sumpin'.
Old Apr 5, 2018 | 10:59 PM
redbeard1's Avatar
Hello,
This tool may seem gimmicky but has quickly become the first thing I reach for to help diagnose noises. It should help you identify the exact part that is making the noise. Best 15 bucks I spent on my car.
Remember to test it on normal noises (like a room fan, a computer fan, etc) to get used to the sound level before putting the device in your ears and touching the metal rod to a car engine. It seems to amplify sound by several factors. I usually put earplugs in my ears before putting the ear buds near my ears.
Amazon Amazon
Old Apr 5, 2018 | 11:08 PM
Originally Posted by redbeard1
Hello,
https://www.amazon.com/Lisle-52500-M.../dp/B0002SQYSM
I got a pair of these and it's great! A piece of tubing or hose works in a pinch, too.
Old Apr 6, 2018 | 12:47 PM
Jrad96TL's Avatar
Sounds like it coming right from that corner
Old Apr 6, 2018 | 12:49 PM
Jrad96TL's Avatar
And the sound will actually change a little bit under acceleration
Old Apr 6, 2018 | 02:37 PM
losiglow's Avatar
Sorry. Your car has the ebolaids.
Sounds like air.
I'd clean and check the EGR first. Remove it, clean the interior with brake cleaner and reinstall it. Make sure it's on tight.
Then check the PCV valve. Remove, clean, or replace. It's a bit tricky to find. It's attached to the front valve cover, kind of under the intake manifold.
After that, stick some tape around parts of the intake manifold, throttle body and other areas where air could escape to see if the noise changes. If it does at certain places, then you can deduct that air might be leaking from that spot.
Check all vacuum hoses. There are a bunch coming out/going into the throttle body. Make sure they're all tight. Check for holes or cracks in the hoses as well.
Old Apr 6, 2018 | 02:42 PM
sounds like pinhole leak to me!
very high pitched - small hole.
515kbpUA7
28
Jun 28, 2013 08:10 AM
Fluffhead
1G TSX Problems & Fixes
Sep 18, 2011 05:33 PM
CLsuperhero
May 31, 2006 11:07 AM
S A CHO
May 15, 2006 08:15 PM
98AcuraCLpimp
Dating & Relationships
Jul 26, 2004 01:45 AM
