HID problem
Old 06-12-2009 | 11:54 PM
elkechon's Avatar
too much money for
Exclamation HID problem
i installed my hid fogs and they worked fine until the next night when they didnt wanna turn on could the ballast be bad? HELP
Old 06-13-2009 | 09:41 AM
ssmtl2nv's Avatar
2009 g37s 6mt
could be ballast or connection problem..... happened to me
Old 06-13-2009 | 09:46 AM
CCBBUUMM's Avatar
Are both sides out?
Hook up oem connector to stock bulbs
Did the stock bulbs turn on?
Yes - you got power
no - check fuse
Is one side out?
Try the bulb on the other side
Did it work?
Yes - Ballast could be bad - Check connections too.
No - Bulb is shot
Some general troubleshooting may help you solve the problem.
Old 06-13-2009 | 10:55 PM
elkechon's Avatar
too much money for
^ i think it is the fuse cause both sides are out and oem bulbs dont work either
Old 06-13-2009 | 10:56 PM
elkechon's Avatar
too much money for
where is the fog light fuse for an 08 tl?
Old 06-14-2009 | 05:41 AM
CCBBUUMM's Avatar
Its in the fuse box under the hood. Usually on the left hand or right hand side. I'm not positive on the 08 TL as the 09 is my first Acura. Check your owners manual.
Old 06-14-2009 | 09:41 AM
Trew's Avatar
Not sure about the 08 but the 05-06 does not turn the fogs on if the high beams are on. Did you check to see if your high beams were on?
Old 06-14-2009 | 11:20 AM
OneWickedTypeS's Avatar
MY KBP IS BTR THN URS...
Are u running straight off the factory harness?
Thats the way I initially hooked mine up but only one side wants to come on so. I bought the relay kit, which I have not had the opportunity to install yet.
Old 06-14-2009 | 11:58 AM
CCBBUUMM's Avatar
GOOD POINT....
mine has this option.
Old 06-14-2009 | 12:22 PM
jguerra23's Avatar
Looking for new mods
Fuse is on under the hood
i belive is a 15.. but dont qoute me.
SidhuSaaB
05-30-2020 12:40 AM
12vancover
10-16-2015 12:04 PM
Matthew Purpura
09-25-2015 06:10 PM
95oRANGEcRUSH
09-25-2015 12:50 PM
AmplifiedDetails
09-24-2015 02:55 PM
Quick Reply: HID problem
