HELP - what is the size for the brembo caliper bolts ?
So i'm kind of screwed,my front tl-s brembo caliper bolts are seized and some came out with part of the thread.I'm looking to buy a tap and die set,but not really sure which to get.I know this bolts have a 19 mm head and a 14 mm diameter anyone knows the thread pitch.
Is it 14mm x 1.5 or is it 14 mm x 1.25?
Please help.
Please help.
you can take a bolt to a local machine shop... they would be able to tell you. I had mine off the other week. THey were hard to budge. I needed PB blaster to loosen them and then a long pipe handle.
Thanks bro,defenaly going to get a pipe otherwise that bitch aint coming out.i ended up buying a thread pitch gauge, so i'll find out today if it is 1.50 or 1.25 .i'm going to have to tap and die the screws and the caliper hopefuly that will work.
