Help .!!! Tranny light blinking !!! What to do ??
Old Oct 11, 2010 | 11:00 AM
ShamelessTL's Avatar
Hey Az
I can't beleivw it. My car has only 53000 miles on it . It's a 2006 TL. This morning like any other morning I started my car and was about to head out to work when I looked down and saw the green light next to the "D" flashing. I'm really nervous right now. I took the car out for a spin and it drives like normal. I did notice it taking a little longer like 3000-3500 rpms before shifting but it shifts smooth still . The dealer had changed the ATF oil back around 46000 miles and the car still is running good. But this flashing light has me worried. I just recently changed my battery a few weeks ago but I don't think that is the problem. Help someone..... I have been on hold with the stealership for hours and still no response. What could be the problem? Thanx alot for any help
Old Oct 11, 2010 | 11:24 AM
TLDude876's Avatar
Chapter Leader (Houston)
Sounds like you need to change out your 3rd and 4th gear pressure switches. They cost like $35 a piece. Do a search on "interesting conversation with transmission builder" and read that thread.
Old Oct 11, 2010 | 02:10 PM
I hate cars's Avatar
I would do the switches regardless but you may have other issues. It could be just a bad sensor such as a speed sensor or the ECU could have detected slip.
Catching auto trans issues early on is very important if you have any hopes of fixing it without a rebuild.
You can start by checking the condition of the fluid and then pulling codes to see what triggered the light.
No matter what happens, I would replace the factory fluid with Redline Racing and replace the 3rd and 4th gear pressure switches.
Old Oct 11, 2010 | 02:37 PM
nfnsquared's Avatar
Originally Posted by ShamelessTL
Hey Az
Owner's manual pg 181 (2004):
The ‘‘D’’ indicator comes on for a
few seconds when you turn the
ignition switch to ON (II). If it
flashes while driving (in any shift
position), it indicates a possible
problem in the transmission. Avoid
rapid acceleration, and have the
transmission checked by an Acura
dealer as soon as possible.
Old Oct 12, 2010 | 10:38 AM
Thanx guys..... I'm just worrying if I caught it too late I haven't drove the car since. I'm still trying to make a appointment at the dealer. My biggest concern is if something is wrong I probably have to warranty now ...... The light flashes even when the car is parked. I could just start it and after a few seconds it comes on and stays on blinking ....
Old Oct 13, 2010 | 08:53 PM
Just a update guys..... Took the car into the dealer and there response was that a ATF temperature sensor some part number 28650-rdg-004 was bad. Does this make any sense to anyone? When I asked the guy at the dealership if the tranny was over heating he said no it's just a sensor that sometimes goes bad for no reason ? Ohhh and it's just gonna cost me around $326 plus tax to fix ...... WTH to do now
Old Oct 13, 2010 | 08:59 PM
AMUA6's Avatar
ScoobyZINE
Buy the part and fix it yoself! Be thankful they're not wanting to drop your trans on the spot haha
Old Oct 14, 2010 | 03:13 AM
jwr0ng626's Avatar
holy crap 326 for a sensor?? reeeeee-diculous
Old Oct 14, 2010 | 04:19 AM
TLDude876's Avatar
http://www.acuraoemparts.com/delray/...y1=&inputstate=
Old Oct 14, 2010 | 04:21 AM
01tl4tl's Avatar
ck with our sponsoring dealer/suppliers like wholesalepartsguy for the part
ck diy section for help on install
dealer price --did that include the standard $100 for diagnostic?
unless you got a CPO car or bought an aftermarket warranty--after 50kmiles on most parts... you are on your own
certain things like smog parts have longer warranty
if you have a flashing light, cel or other--any parts store can read the codes for you--save that 100 bucks the dealer wants for the same test,,you can buy the scanner tool for 100!!
Ca residents cant get free scans,,-but you can buy a scanner--go figure
Old Oct 14, 2010 | 05:04 AM
libert69's Avatar
18psi
Buy the sensor from the link above and follow these directions directly from the manual. Youll save 250$
Yikes
May 3, 2021 04:29 PM
BigJilm
Sep 21, 2015 08:32 PM
Junior Noboa
Sep 21, 2015 06:28 PM
whitesoxsfan12
Sep 13, 2015 02:09 PM
HeloDown
Sep 8, 2015 06:51 PM
