Help on AT shifter removal
Old Mar 31, 2011 | 12:04 PM
paperboy42190's Avatar
Does anyone have a diy on how to remove the shifter trim for an automatic? I accidently braked too hard and my drink spilled around the shifter trim. I've cleaned up most of it but the shifter is a little sticky to move. It doesnt get stuck or anything but it definitely doesnt feel as smooth as it did before.
Old Mar 31, 2011 | 01:55 PM
invalidalias's Avatar
is it the frame around the gears selector indicator or that flat piece under. either ones pop out. Yea from exp if soda or coffee gets down there it will eventually wear it out then you have to replace that whole shifter unit.
Old Mar 31, 2011 | 02:36 PM
nalek's Avatar
That trim piece around the top just pops off.
Beyond that, you get into an assembly, that you probably do not want to disassemble.
I know you can take the part off that has the P-R-N-D etc.. but I dont remember how to do it. I think it is relatively easy to take off once the whole shifter unit is out, but not while still in the car.
To get the shifter out, you have to take the lower part of the dash off where the storage bins are.
Old Mar 31, 2011 | 02:46 PM
Originally Posted by nalek
[/URL]
THATS the picture i wanted to see! cuz the drinks made itself down underneath the shift knob area and i would need to get mine down to where it looks like the above picture to clean it
Old Mar 31, 2011 | 02:49 PM
nicourt's Avatar
OP you might try spraying a liberal amount of WD40 into the top of the shifter and working it back and forth.... As stated above this unit is not somthing you want to start pulling apart... WD is known to dry out moisture and lubricate at the same time without harming or shorting electrical contacts...... GL
Old Mar 31, 2011 | 02:53 PM
pohljm's Avatar
^ or use an electrical contacts cleaner liberally
Old Mar 31, 2011 | 05:54 PM
Hmm wd40 is s very good idea if it can saveme the trouble of removing the shifter. I will give it a try
Old Mar 31, 2011 | 06:47 PM
csmeance's Avatar
be careful with WD40 as it can damage some of the trim and stuff under there. Do it the right way and clean it out properly with Electrical Contact cleaner.
Old Apr 7, 2011 | 01:54 AM
i used silicone lube and it worked perfect....no more sticky issues...
Jul 16, 2017 07:33 AM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
MikeJM310
Sep 24, 2015 07:24 PM
