Help needed
Help needed
Well I got a 04 Acura tl and in the dashboard it is displaying the vsa light and abs and a triangle light with exclamation point does anyone how to fix these lights. And I get horrible gas mileage
MeelzJaw Auto Service
One thing you need to understand is that cars now do not have a simple repair. This sounds like an issue with the traction control/abs system. It could be a bad sensor, broken/ corroded wire or a faulty module. It pretty hard for someone to pin point where the issue is without looking at the car. The car is gonna have to be diagnosed. Electrical is a tad bit specific. My advice is to look for any broken wires or loose connections at the wheel(for the abs sensors). If you cannot see anything obvious then you are going to have to take it in to your tech. Maybe have them scan the vehicle and possibly pull some codes.
As per gas millage, how many miles/km on the vehicle?
Are you checking your tires [pressure regularly ?
Are you putting in the proper gas?
Agree with the last post. Take it to your local AutoZone or what ever auto parts store you have nearby and get the codes pulled.
As for the mileage? Define what horrible is to you. 15MPG is bad for most, while others aren't happy with 25MPG. Generally these cars are good for 20-30MPG depending upon conditions.
BANNED
^bro...
nobody cares about the air filter.
It is installed properly. i bought the car from auction with front end damage on left side i changed the axle and multiple sensors could it be that the ecu doesnt recognize the sensor because the vsa sensor was torn and i rewired it.
BANNED
Yes.
TLDude876
12-28-2016 03:18 PM
2015TLX
09-11-2015 02:56 PM
nuldabz
09-03-2015 05:49 PM
