Help! Incredibly Noob Interior LED Problem
Old Aug 14, 2013 | 12:28 AM
Kaiii's Avatar
Wow Amaze Such TL-S
Hi guys,
I recently bought a set of interior LED's from Amazon, since the reviews were good and it was pretty dang cheap. ($8.25!).
Came with (as seen on the sale page):
Map light (2 pieces)
Dome light (2 pieces)
Step/Courtesy light (2 pieces)
Trunk/Cargo area (1 piece)
So I install the dome lights into the rear, and the Step/Courtesy lights into the doors, and they actually look great, despite the price. Crisp, bright white.
BUT, then I try to install the Map lights into the front (the ones by the sunroof button) - these things are supposedly plug and play, but I end up blowing the fuse when I plug the LED in (tried twice, happened twice). Am I doing something wrong? Also, the terms "Map" and "Dome" are frustratingly vague. I'm assuming Map is the front and Dome is the back? And does this even matter / are the LED's not interchangeable?
If anyone knows what's wrong or has bought this cheap Amazon set before, help would be much appreciated
Old Aug 14, 2013 | 01:27 AM
paperboy42190's Avatar
the dome is rear and map is front. they all use t10 sockets so it should all be the same, but I think maybe the LED could be defective thats why its blowing fuses, or maybe you are installing them with the lights in the ON position.
Old Aug 14, 2013 | 02:37 AM
Kaiii's Avatar
Wow Amaze Such TL-S
Ah got it, thanks. If they're all T10, then yea I guess it doesn't matter.
I had the lights off when installing. After close inspection it looks like one of the metal connectors on the LED that I was installing is extremely short. I can't imagine why this would cause a fuse to blow but that's the only peculiar thing I noticed.
I think I'll message the seller and ask for a replacement...
Old Aug 17, 2013 | 04:07 AM
WolfgangVonBrutal's Avatar
I'd say the LEDs are most likely defective, I got mine from Superbrightleds, did the whole interior with them and they're fine. With the exception of one of the map light LEDs flickering on occasion, but that's just a bad connection inside the LED itself, not where it connects to the socket. I'd say just order 2 LEDs from Superbrightleds, but the color probably won't match what you got from Amazon.
Old Aug 19, 2013 | 09:01 PM
Kaiii's Avatar
Wow Amaze Such TL-S
thanks guise. i just complained to the seller and for some reason they decide to send me 4 lights to replace the two I asked for. well this worked out nicely
oo7spy
Jun 19, 2023 12:48 AM
Feb 25, 2020 09:57 AM
tiresmokinV8
Sep 15, 2015 09:10 PM
Sep 14, 2015 10:09 PM
oyayjoe
Sep 12, 2015 04:40 PM
