Help with headlights. Please!
So over the weekend I installed switchback led turn signals. I did the driver side first, and had hyper flash. I figured I would so I installed the resistors that came with them and it was fixed. Then I did the passenger side with the resistor. And now it has hyper flash. So I don't know what to do. driver side is fine and passenger side has hyper flash, any suggestions on how to fix it would be much appreciated.
p.s. I have a 07 type s
and installed these
and installed these
ok got ya, the only problem is I had to use t taps or what every you call them to splice it to the wire, so I don't know how easy it will be to take those off and re do it. with out cutting the wire in half
so, are you sure you T-tapped the passenger light relay correctly?
this issue isnt as hard as you are making it out to be.
it can only be a few things...
the resistor itself or your install work.
double check both.
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
Marmbo
4G TL Problems & Fixes
Sep 21, 2015 09:39 AM
