Headlight turning off but turns back on again
Old Oct 20, 2011 | 05:54 PM
seanmanila's Avatar
I have an 04 TL and I just noticed that my left headlight turns off after a couple of mins. but when you turn the switch off then on again the headlight lights up but still goes off after a while.
Anyone have experienced this before? Can't be the bulb because it turns back on, I cant really think of anything at the moment other than something being loose but why does it turn back on.
Thank you in advance
Old Oct 20, 2011 | 07:37 PM
seanmanila's Avatar
Update, the left light has turned pinkish and right one is still blueish in hue
Old Oct 21, 2011 | 01:28 PM
ez12a's Avatar
the overexplainer
Replace the left bulb.
Also dont turn your HIDs off/on repeatedly like that. You'll wear other things than just bulbs.
Old Oct 21, 2011 | 02:26 PM
seanmanila's Avatar
thanks, hopefully that fixes it.
It could also be the ballast that causes it to turn off I wonder.
Old Oct 21, 2011 | 03:29 PM
KN_TL's Avatar
I'd suggest replacing them in pairs. If one is going the other is likely not far behind.
Old Oct 21, 2011 | 03:36 PM
seanmanila's Avatar
Just bought a pair of 6000k D2S from HIDExtra, hopefully that fixes it
Old Oct 21, 2011 | 06:55 PM
ez12a's Avatar
the overexplainer
maybe. but for sure your left bulb is in need of replacement. Good you ordered a pair since the remaining one probably color shifted due to age since new. Replace the bulbs and then cross the bridge with the ballasts if it comes to it.
Old Oct 22, 2011 | 12:49 PM
seanmanila's Avatar
what do you mean by cross the bridge?
Old Oct 22, 2011 | 09:51 PM
cjTL's Avatar
I'm Craig
Yep- pink eye is a sign that the xenon bulb is about to go completely. Sometimes they'll turn a yellowish color too. Did you ever get them changed? That likely was the issue with the switching off/on thing.
Old Oct 23, 2011 | 12:03 AM
seanmanila's Avatar
Im still waiting on the bulbs. Crossing my fingers and hoping that fixes it
Old Oct 27, 2011 | 10:47 PM
seanmanila's Avatar
I think the headlight replacement fixed it. Although it seems like the 6000k is not as bright as oem
Old Nov 1, 2011 | 09:07 PM
gogators22's Avatar
OEM is 4300K.. I would have gone with 4000K or 4500K. Closest to sunlight brah
Old Nov 1, 2011 | 10:15 PM
cjTL's Avatar
I'm Craig
Yeah there's a certain sweet spot between brightness and whiteness in xenon temperatures.
http://www.manyadeal.com/page.html?id=24
Old Nov 8, 2011 | 11:58 AM
Araf's Avatar
8th Gear
Back in August my dirver side headlight stopped working, it was raining. Then it came back on, which sucked, because i thoguht it was simply the bulb. THen it would come on and off jsut as mentioned earlier in the thread.
Nonetheless, changed the bulb on both sides, and also the igniter on the problem side. It worked for a week, then the headlight started on and off again, it would go off, then i would take off and put on the switch and it would come on again. Now all of a sudeen for the past two weeks, it is completely dead.
You guys think it is the ballast???
JnC
Sep 11, 2015 06:06 AM
theinsvnity
Sep 10, 2015 10:22 PM
HeloDown
Sep 8, 2015 06:51 PM
Phambam12
Sep 6, 2015 06:57 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
