Half of steering controls lights are not working
Old Apr 13, 2010 | 02:22 PM
UA6/7's Avatar
I just recently realized that only upper phone button "to make the call" on the left of the steering wheel is lighting up and the "end" button is not. Also, the "cruise" button is the only one out the the other cruise control buttons that currently lights up. The car is 2005 with 62k miles, seems highly improbable that this is happening due to age or usage. Any ideas? Dealer wants $130 just for labor.
Old Apr 13, 2010 | 02:41 PM
gremlin190's Avatar
6th Gear
I also am having the same problem. Mine is an 06 with about 50,000 miles. I need to check the fuses, but we are also having an intermittent problem with the tpms? Aargh, I have a feeling this won't be cheap!
Old Apr 13, 2010 | 02:53 PM
gremlin190's Avatar
6th Gear
https://acurazine.com/forums/showpos...6&postcount=76
Apparently this is a normal issue with these cars. I think it's a type #74 bulb, but I'm not certain. Still trying to find it for certain.
Old Apr 13, 2010 | 02:54 PM
UA6/7's Avatar
I checked all the fuses. Nothing.
Old Apr 13, 2010 | 07:58 PM
silver_alty's Avatar
the interior bulbs burn out really fast. i usually keep my interior lights dimmed to increase life of the bulbs.
Old Apr 13, 2010 | 11:28 PM
UA6/7's Avatar
true, does anyone know how to remove those aluminium corners; cruise control casing. I figured you would probably have to remove the steering wheel air bag/horn cover.I could also look at the dealers diagram. Really dont feel like paying over $130 for a $7 bulb.
Old Apr 17, 2010 | 02:21 PM
tony 1172's Avatar
Cad designer
the bulbs do burn out the light that the interior illuminates are very bright compared to other cars i have seen if you know someone who works in a body shop since there always removing & replacing the air bags on the steering wheels they may have some info that might help.
Old Jun 6, 2019 | 12:39 PM
Bob McKee's Avatar
Disconnect battery first. Underneath steering column a small door to remove to unplug the airbag. Two screws to remove on the sides of the steering column to release the airbag. Small screws on the back of the corner pieces. Flathead screwdriver can remove the bulbs.
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
wusty23jd
Sep 24, 2015 11:41 AM
drewdeezy03
Sep 3, 2015 08:04 PM
pesobreeze
1G RL (1996-2004)
Sep 3, 2015 12:26 PM
