Grinding noise when turning and start the engine
Old Feb 14, 2010 | 09:36 AM
spree-dakid's Avatar
I have a 2004 Acura Tl about 3 years now and recently started having issues with grinding sounds when making both left and right turns. Its pretty loud. I was wondering if anyone else has had or is having this issue. I dont know if it has something to do with the weather because after the car is running for a while I dont hear the noise that much.
Thanks for the feedback.
Old Feb 14, 2010 | 10:59 AM
csmeance's Avatar
check your power steering fluid level.
Old Feb 14, 2010 | 11:46 PM
Smitty27's Avatar
Does the noise go away after the engine warms up?
Old Feb 17, 2010 | 03:11 PM
Thanks csmeance. I will check the fluid tomorrow.
Smitty27. The noise is very loud when I first start the engine up then after driving around after the engine warms up you can hardly hear the noise.
Old Feb 17, 2010 | 08:06 PM
erick3's Avatar
when you speak of this "noise," is it more of a whine? sounds like the powering steering pump. it seems to be a common problem with all of our cars. go buy an o-ring and replace it. there's a diy in your 3g garage.
Old Feb 17, 2010 | 09:18 PM
Radcliffe1's Avatar
From the Desert 2 the sea
Sounds power steering related or rack and pinion. Growl, humm or whine - makes a difference.
I second the checking the steering fluid.
Could be the o-ring needs to be replaced on the pump per some TSP out there.
Old Feb 18, 2010 | 07:16 PM
wreckon06's Avatar
I've had the same problem. I took it to Acura and apparently there's a recall so they took care of it. You might want to do the same
Feb 25, 2020 09:57 AM
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
PortlandRL
Sep 14, 2015 12:01 PM
iCrap
Sep 11, 2015 06:21 PM
ninersfgiantsfan
Sep 9, 2015 01:14 PM
