Dash reflection in windshield
Old Feb 14, 2010 | 02:25 PM
gojoTL's Avatar
Just purchased an '08 Acura TL. Taking the car for a test drive and noticed that when driving directly into the sun, the dash is reflecting back into the windshield. Very distracting. Any suggestions or fixes for this problem?
Old Feb 14, 2010 | 03:41 PM
csmeance's Avatar
take a damp towel and wipe down the dash board lightly. Follow up with a dry towel to help get any residual water off.
Then clean the inside of the windshield as dirt and grime can accumulate thus causing that relfection.
Old Feb 14, 2010 | 04:22 PM
04TL4P3's Avatar
I have always had this problem whether it was dirty or not and its really bad when u armor all the dash . I recently got some polarized Oakleys and they completely take the glare away. Not saying u have to go out and buy Oakleys but any polarized glasses should work.
Old Feb 14, 2010 | 05:41 PM
Yakuza17's Avatar
I second the polarized sunglasses to reduce the glare from the dash. It also helps with reflections a lot, especially when you're driving in bright sunny conditions on wet roads like after a thunderstorm.
Old Feb 15, 2010 | 08:47 AM
Bender's Avatar
LOL Armor all. Keep using that if you want to ruin your dash.
Old Feb 15, 2010 | 01:07 PM
04TL4P3's Avatar
LOL I dont use cheap ass armor all I use quality products but alot of times dealers will use armor all or some other type of product that creates alot of shine and it causes alot of glare and he said he just bought the car from a dealer
FYI If you use a quality interior conditioner or leather conditioner on your dash it will actually protect it and keep it looking new longer...
Old Feb 15, 2010 | 01:08 PM
Jesstzn's Avatar
Thats pure bullshit ... old wives tale ...
Old Feb 15, 2010 | 01:10 PM
Jesstzn's Avatar
I never use anything more than Meguiars #40 on the dash but to address your problem try using the Woolite solution on your dadh and it will remove a lot of the dressing that was put on it.
Old Feb 15, 2010 | 01:35 PM
Bender's Avatar
Go ahead and look up armor all and dash cracking, something to do with high silicone content.
Old Feb 15, 2010 | 01:38 PM
Jesstzn's Avatar
Go ahead and look up armor all and dash cracking.
No .. you go look it up .. that was 30 years ago .. the new formula is not a problem.
Would you suggest 303 instead?
Old Feb 15, 2010 | 01:56 PM
Bender's Avatar
https://acurazine.com/forums/wash-wax-23/put-armorall-my-dash-doors-bad-idea-48526/
Old Feb 15, 2010 | 02:10 PM
Jesstzn's Avatar
Very informative wives tale ..... Todays Armoral is no different than any of the other "non" Clear ( white ) dressings
The formula they have sold for the past 20 + years or so, no way cracks dashes.
It may appear too glossy for some, it may be not expensive enough for some, but in reality, it is just a PDMS resin, with a little mineral spirits to increase the "wow" factor, but nothing in it that is the source of the very old 1970's formula that all the uninformed focus on.
Have never seen the new formula cause cracking when correctly applied, which is actually due to the loss of plastizers from the vinyl, same with any of the other PDMS resin based products.
303, Mequiar's, Eagle One (VW's product is Eagle One), etc these are water borne, Polydimetalsiloxane resin formula's, every last one of them.
The present ArmorAll only differs from many other PDMS dressings, (polydimethalsiloxane) by percentage of the resin mixed into the water that is it's carrier to the surface.
Be it Eagle One, Zanio, Mequiar's, Mother's, 303 etc, all the "white-water based" dressings are PDMS.
This resin DOES NOT DAMAGE vinyl or tires, to have that, happen one would have to use the "greasy kid stuff"/"getto shine" products, which contains petroluem distillates and dimethal silicone fluids.
303 has a higher resin content, the maximum that can be used, which is why it cost more.
Most of the mass marketed PDMS are usually around 18 to 20%, most professional dressings are between 22 and 27%.
Cost is an issue for professional detailers, and even the higher resin 303 does not last "that" much longer than a, say 24% content.
Just looks better for a couple of days.
The "UV" protectant adverstising is pure bunk, it is not possible to actually put "UV" blockers in these types of resins and if it could be done, the product would have to be marketed at about 3 to 4 times a higher price, as a UV component is very, very expensive.
The claim of "UV" protection comes from the resin barrier created and the additional shine, which reflects the damaging UV's.
The real advantage of using a PDMS is protection from the far more damaging ozone that is present. This protection is only there as long as the product is.
Old Feb 15, 2010 | 08:45 PM
pohljm's Avatar
I like the 303, it leaves more of a matte finish which is less reflective
Old Feb 16, 2010 | 12:29 AM
04TL4P3's Avatar
Man I honestly have never looked into it this much but you atleast sound like you know what you are talking about. Iv just heard that if you are going to use armor all or other products like it you have to keep a fresh application on your dash or it will dry out and crack over time.
Old Feb 16, 2010 | 12:41 AM
Bender's Avatar
All he did was Google copy and paste. Here is part of it. It is not verbatim but you get the point.
http://www.autopia.org/forum/car-det...ash-glare.html
"303 has a higher resin content, the maximum that can be used, which is why it cost more.
The "UV" protectant adverstising is pure bunk, it is not possible to actually put "UV" blockers in these types of resins and if it could be done, the product would have to be marketed at about 3 to 4 times a higher price, as a UV components is very, very expensive.
The real advantage of using a PDMS is protection from the far more damaging ozone that is present. This protection is only there as long as the product is. "
Be it Eagle One, Zanio, Mequiar's, Mother's, etc, all the "white-water based" dressings are PDMS.
Enjoy the power of Google making people look genious since 1996.
Old Feb 16, 2010 | 12:47 AM
Bender's Avatar
http://www.google.com/search?hl=en&s...&aq=f&aqi=&oq=
Old Feb 16, 2010 | 08:40 AM
Jesstzn's Avatar
Cool eh... you just googled and got my postings in Autopia back in
July of 04 and I even gave credit to the source.
Old Feb 16, 2010 | 10:10 AM
Bender's Avatar
Yes, It is cool. You must have made it onto this obscure jeep board as well. Either way there are tons of links and talk about armor all and other products in this post.
http://www.jeepkj.com/forum/archive/...p/t-31736.html
Old Feb 16, 2010 | 10:31 AM
Jesstzn's Avatar
Ya .. 67 Customs is another very knowledgable detailer ... anyway we have drug this way off topic ..
Old Feb 18, 2010 | 09:10 PM
gojoTL's Avatar
I purchased the polarized glasses and that fixed my issue.
Thanks for the detailed information on the dash protectant. I'll possibly give one of these products a try.
Old Feb 18, 2010 | 09:33 PM
AMUA6's Avatar
ScoobyZINE
Tint the windshield!
Old Feb 18, 2010 | 09:41 PM
dave_ramkumar's Avatar
2011 ZCP E92 M3!!
+1 i use it all the time without any problems on any of my cars
Old Feb 18, 2010 | 09:42 PM
2011 ZCP E92 M3!!
Originally Posted by smokd05
tint the windshield!
ftw
Old Feb 18, 2010 | 10:07 PM
Red Voodoo's Avatar
Area on my XM
I've just gotten used to the reflection. Doesn't bother me so much anymore. I can imagine that using a high gloss protectant would amplify the problem. Meguiars is my preferred brand. I'm not jumping on that bandwagon about Armor-All. Not the new formula, anyways.
TheMuffinMan
Jun 2, 2022 07:11 AM
hashbrown
Feb 18, 2022 11:20 AM
tsx_boy
Dec 13, 2019 08:33 PM
rhdune16
Sep 28, 2015 11:31 AM
2Quik
Sep 23, 2015 01:03 PM
