Got the dreaded P0741 Code today
Old Oct 19, 2012 | 02:37 AM
AbyssBlue2005's Avatar
Today I was driving along and my CEL came on. Later that night on my way to work I was driving about 60mph and the car started trying to downshift and the transmission started slipping. After waiting a few minutes I limped the car to work and it only acted up one more time. I know this problem has been discussed in the past but has anyone found a solution other than replacing the transmission? I hooked the car up to a Snap-on Solus scanner and it gave me tests to run on the solenoid but I don't have the time tonight. I would rather try to replace the $300 solenoid than the transmission but if I am chasing my tail by doing it I would rather just rebuild/replace the trans. Thanks for any help in advance.
Old Oct 19, 2012 | 07:15 AM
truonghthe's Avatar
well if it slip then usually you will need a new AT, our TL AT isn't bullet proof like IS350 or G35.
Old Oct 19, 2012 | 01:46 PM
carbngrytl's Avatar
How many miles are on your car? Can't believe the tranny on an 08 is toast already.
Old Oct 19, 2012 | 01:56 PM
TheChamp531's Avatar
Chapter Leader (San Antonio)
Solenoids cost like $60-80 and is probably one of the easiest things to do.
Worth a shot. Buy some Redline ATF + 3rd/4th gear solenoids and see if it helps/fixes it.
Good luck
Old Oct 19, 2012 | 08:03 PM
Slpr04UA6's Avatar
-------Tim-------
Here is the thread with the part #'s for the pressure switches/solenoids......
https://acurazine.com/forums/3g-tl-2004-2008-93/very-interesting-conversation-my-transmission-builder-tl-721508/
Old Oct 20, 2012 | 09:10 AM
96SC4's Avatar
oh geez.
i just got an 07 with 36k miles on it..
i thought this issue was only on the 04 and 05's...
Old Oct 21, 2012 | 07:20 AM
tonto340's Avatar
The transmission on my 07 Type-S went out at 79K. I had it rebuilt at AAMCO but would received a much better price and warranty a the dealer.
Old Oct 21, 2012 | 02:59 PM
96SC4's Avatar
great.
i guess i better stay on top of the fluid changes and pressure switches(or whatever they're called).....
Old Oct 21, 2012 | 09:08 PM
The tranny that went out is in my 2005. I have been very careful with the 2008. I bout the 2005 fairly cheap due to hail damage. I just got done painting it and had only driven it for a couple of weeks before this. I have checked all of the solenoids. Everyone ohmed out fine so I'm just facing the facts that the trans is in need of a rebuild. Haven't decided whether I'm going to rebuild myself or take it somewhere.
Old Feb 25, 2019 | 09:59 PM
Nickh36's Avatar
Knock sensor
It could be a Knock sensor , I had to replace 2 of mine on my 2004 TL
TypeS860
Jan 10, 2026 11:11 AM
Mike Pilipenko
Mar 26, 2024 09:21 PM
Skirmich
Oct 1, 2015 12:59 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
flybyglass
Sep 24, 2015 01:12 PM
