GM Synchromesh Transmission Fluid - Friction Modified
Old Sep 18, 2012 | 07:32 PM
  #81
Bruce Banner's Avatar
Just had this put in yesterday. Maaaaaaaaannn this fluid is soooo much better.
Old Sep 18, 2012 | 07:40 PM
  #82
LGcbp8's Avatar
Since this thread was revived today I thought some peoples might find this link helpful. Just copy/paste that part# from previous posts above (88900399) in the Part Number Search field on the right of the screen and it will come up. It's $9.48 per qt on there and it looks like they sell it by the qt, so your not stuck buying 6 at a time (unless you want that many).
Note it says free shipping on there to, but they do charge a $9.99 handling fee so thats a wash. But still $38.43 to your door is pretty good. I'll probablly pick some up later this week.
http://www.gmpartsoutlet.net/?type=parts&start=1&home=1&bcsi_scan_2285D5E8088A7CAA=UUL70GS JMEB7wcNpoBZfZSi+OEQDAAAA48iOCA==
Old Sep 20, 2012 | 01:59 PM
  #83
stockashelltypeS's Avatar
9th Gear
Great info, I called the dealer and they gave me a different part number and saying that's the same, I was kind of worry that's the wrong fluid. btw your price is so much better than here VA $14 each
Old Sep 28, 2012 | 05:32 PM
  #84
JJTLTYPES's Avatar
4th Gear
Hi Everyone, FYI AMSOIL no longer recommends their MTL for the TL-Type S six speed due to the LSD.
From AMSOIL:
John;
After further research, we agree with the label and do not recommend it for use in this application. The part number Acura recommended over time has been updated. Our MTF meets the older specifications as claimed, but does not technically meet the newer part number specifications due to the addition of limited slip performance now included in the product recommended. We don’t think its use will cause any problems, but cannot be sure, so if you have not used it yet, we do not suggest trying it. We have no other product to suggest for this application at this time.
Thank you for bringing this to our attention.
Byron Selbrede
Technical Services
AMSOIL INC.
ADDRESS: 1 AMSOIL Center, Superior, WI 54880
E-MAIL:bselbrede@amsoil.com
PHONE:715-392-7101
FAX:715-392-3097
Old Aug 15, 2013 | 05:51 PM
  #85
Joey tl's Avatar
04' tl 6 spd
Question..... Went to a distributor here in Canada and they told me ACDELCO #89021808 but it doesn't say friction modified in the bottle is this the right stuff
Old Aug 15, 2013 | 07:04 PM
  #86
the correct part number is AC delco 10-4014
Old Jan 3, 2015 | 12:54 AM
  #87
scottypAcuratypeS3182's Avatar
revival of this thread
Hey guys just Bought and Acura 2007 TL type S. Went and test drive it and seemed to shift fine. Now that I have it , the infamous 3 rd gear is shifting weird. It feels sticky or like it wants to pop out. It does pop out on occasssion. It has 135k miles on it. Don't know if tranny has ever been worked on but I'm pretty Damn sold on this GM FM syncromesh y'all talked about. Will keep you updated. Hopefully I'm not a dumby buying into some myth. Lol
Old Jan 26, 2015 | 09:25 AM
  #88
jeeva86's Avatar
'08 TL-S 6MT
Don't worry, get the GM FM and you're good.
Anyone know how often the fluid should be replaced. I changed mine ~3 years ago and I feel it sorta struggle to get into 3rd, so wondering if it's due or if there's a more serious problem.
Old Jan 28, 2015 | 02:58 PM
  #89
Due_Diligence's Avatar
Wish I would've known this back when I had my rsx type s in high school
Old Jan 28, 2015 | 05:41 PM
  #90
deepbluejh's Avatar
For these cars I wouldn't go any longer than 2 years or 20k miles before changing the MT fluid.
Old Sep 19, 2015 | 01:58 PM
  #91
Boogsephine's Avatar
Amazon.com: ACDelco 10-4014 Friction Modified Synchromesh Manual Transmission Fluid - 32 oz: Automotive Amazon.com: ACDelco 10-4014 Friction Modified Synchromesh Manual Transmission Fluid - 32 oz: Automotive
Is that the same stuff mentioned previously? I had my transmission fluid drained and filled about a month ago due to some odd shifting and it shifted smooth like butter after the drain and fill.
Bad news, I used the non friction modified version and it's starting to shift funny again. It'll be a little rough when first taking off in 1st gear and kind of jump and a little rough going into 4th gear.
I read on here that many people do notice the difference between the friction modified and the non modified. Should I drain my current stuff out and use this? I find it really odd that it was perfectly fine for about two weeks and then the problem started again.
Old Sep 22, 2015 | 10:48 AM
  #92
Just purchased the friction modified version of it and going to have it put in this weekend. It shifted a little rough yesterday but was perfectly fine today when I let the guy from the shop test drive it.
I hope this solves my issue!
Old Sep 22, 2015 | 11:56 AM
  #93
EvilVirus's Avatar
First transmission fluid change is at 60k and then every 30k afterwards.
I just purchased mine last week and need to do my change. I just get notchy feel sometimes so hope this help from what other members have experience.
Old Sep 22, 2015 | 01:12 PM
  #94
maharajamd's Avatar
<p>Fresh fluids in general can help a little with that notchy feel. But I wouldn't say the GMSM will alleviate it. The only difference I noticed when I switched way back was I stopped having minor&nbsp;third gear issues.</p>
Old Sep 22, 2015 | 02:18 PM
  #95
quanaman's Avatar
TL-S
My notchy 3rd gear (sometimes even had to let go of the clutch and reengage to get a proper shift) completely went away with the GM Friction modified. Thats the shit you want.
Old Sep 22, 2015 | 03:09 PM
  #96
EvilVirus's Avatar
Exactly the notchy feel is mostly in the 3rd gear.
Old Sep 22, 2015 | 03:31 PM
  #97
maharajamd's Avatar
<p></p>
Mike Pilipenko
Mar 26, 2024 09:21 PM
SidhuSaaB
May 30, 2020 12:40 AM
lanechanger
Oct 13, 2015 10:56 AM
mellsonnj
Sep 24, 2015 04:42 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
