Gas Needle For The Fuel Gauge Stuck Below "E" !!!
I'm having a couple issues with my fuel gauge. The needle is stuck below E and the Gas light is on beneath it. It's been like this for a while now, but I've been ignoring it. Everytime I put gas in thr car, the needle stay stuck on E. All of the other Gauges in the car work except the Gas needle. Any ideas on what's wrong or how to fix this ? I already tried replacing the fuel pump and that didnt work. I also tried sweeping the gauges and they all sweep including the fuel gauge. I changed the cluster and the new one did the same thing. WHAT THE HELL IS WRONG WITH IT???
P.S the gas mileage thing in the after the Trip Computer that tells how much miles is left for the amount of gas also reads --- so i have no idea how much gas is in my Car. PLEASE HELP!!!
bad MICU?
Amazing what you can find with Google.
Trouble Code: B1175
Fuel Level Sensor (Fuel Gauge Sending Unit) Circuit Open
Possible Causes:
Loose or poor connections between the Gauge Control Module and the Fuel Tank Unit
Faulty Fuel Gauge Sending Unit
Trouble Code: B1175
Possible Causes:
Now he tells us
Stay Out Of the Left Lane
Received 1,245 Likes
Did you do the rest of the diagnostic tests in the other thread?
So if the sending unit is part of the pump which has already been replaced, to me it seems like the next steps are to track the rest of the electrical path. Check the connector at the fuel pump...and well, yeah, I have no clue past that. Hopefully some of the other guys that dig in deeper on their cars will chime in eventually.
Certainly sounds like a bad ground or loose connection somewhere. Start at the guage and work your way back.
