Fuel pump
What makes you think the pump is going bad? Have you replaced the relay yet? My car would randomly shut off when I was coming close to a stop/idle - 1 every 3 months or something. Replaced the relay, haven't had that issue happen again in 2 years. It's also much easier and cheaper to replace the relay than the pump.
I just replaced the fuel pump assembly and drove 100 miles after install, so far no check engine light crossing my fingers though. I feel like this code has a lot of variation that it could be, so you could also be right.
I have also added a bottle of Chevron Tech Fuel Injector cleaner.
Do you guys have the part number or any reference material for replacing the relay? I'm having missfire issues at higher throttle usage, and I don't imagine it's the relay, but I'd still like to do my due diligence of research.
Fuel pump ?
I noticed lately that when I first start the car and drive, it has these weird hiccup hesitations at low RPM...seems to get better as it gets warmed up...and much better at higher rpm. Started thinking about it and at 247K miles...I have a feeling the fuel pump is getting tired and old. I would likely start with that over injectors as I am not getting any sort of misfires on any cylinder or anything.
01cl_blk
Jul 9, 2015 10:41 AM
rdx158
1G RDX Problems & Fixes
Jun 11, 2015 01:18 PM
rdx158
May 22, 2015 06:24 AM
StonedCL
Sep 3, 2009 06:46 PM
