Engine shaking & loosing power when accelerating
Old Apr 18, 2020 | 09:18 AM
Glorygang600's Avatar
Last week or so my cars check engine light started flickering so i went ahead and changed the sparkplugs that the codes had come up for To no avail ( was still weak when accelerating from a stop till it hits a higher gears). Last night while on the highway it began to lose power while accelerating to the point that the harder i pressed the gas the lower the rpms went and making a horrendous whining sound while shaking like nothing ive seen before with my car in all the years that I've worked on it. It might have been overheating (all though my temp gauge never when up fluid was pumping out of radiator reservoir) and I don't know what to do at this point my dad said my engine is tarnished but why?? Im at 180k miles on my 2005 tl and tips or clues on how to solve this issue?
Old Apr 18, 2020 | 11:18 AM
Well, what was the exact code? Misfires can be the spark plugs, coil packs, bad fuel...or even worse..loss of compression.
So, start from the beginning. What was the exact code that the car threw?
Old Apr 18, 2020 | 12:01 PM
Honestly don't remember the exact codes on them so Im gonn have them reread and get back to you
Old Apr 18, 2020 | 12:05 PM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
justn is correct. Codes are the best place to start.............
Old Apr 18, 2020 | 03:34 PM
YJLTG-TLS's Avatar
Codes will be helpful but as a preemptive hypothesis, I'm going to guess bad coil packs or a lack of fuel (clogged/sticking injectors or rail, weak fuel pump, etc.). I would start by testing the basics of fuel, use a fuel pressure tester and measure the pressure at the rail and see if it is within spec(not sure myself what it is exactly) then test the coil packs on the designated cylinders then if all that checks out or if you have the spark plugs out anyways, check the compression in each. However, I'm leaning more towards an ignition/combustion issue.
Old Apr 20, 2020 | 11:50 AM
truonghthe's Avatar
If I have to take a guess, I would say the 02 sensors is about to take a shit. But this just a wild guess before OP posting the code.
Old Apr 20, 2020 | 12:15 PM
El_Cheapo's Avatar
Everyone is just guessing.
OP did not give enough info.
Old Apr 22, 2020 | 07:02 PM
GhostTL09's Avatar
App sensor but you wouldn't have shaking so idk. Just a guess on my end too
Old Apr 23, 2020 | 02:20 PM
El_Cheapo's Avatar
It's the engine and might as well replace the tranny to make sure.
Old Apr 23, 2020 | 03:21 PM
Top off the blinker fluid too while replacing coil packs
Old Sep 18, 2020 | 07:47 PM
Just a bit of an update for those in the future took it to the shop and the gentleman over there ended up replacing 2 ignition coils and cleared out a bunch of junk in my catalytic converter/exhaust manifold. (I will post a pic of said junk in the next post) I was told that i didnt need to but it was recommended to replace both manifold and C. converter which makes sense because my car doesnt push as much as id expect when pressing the gas
Old Sep 19, 2020 | 06:28 PM
csmeance's Avatar
cat is built into manifold it's 1 piece, you can buy deletes for much cheaper or hollow out factory ones.
Ahsan
Aug 31, 2014 08:47 PM
rudugama
Jun 4, 2013 11:33 AM
bluerondo
Jan 15, 2012 06:09 PM
steve
Dec 21, 2011 09:50 PM
poisx7
Feb 22, 2005 02:53 PM
