Engine noise leaking into cabin after steering rack was replaced
Old Nov 28, 2011 | 12:47 PM
Salden's Avatar
'04 TL/navi:
Had the steering rack and both lower control arms replaced. When I picked the car up, I immediately noticed I could hear the engine mor eloudly, as if there was a hole in the firewall. The rubber boot over the steering knuckle on the inside of the car seems intact. Mechanic said everything looks ok. I know I am not crazy. Any ideas? It's definately coming from the driver's side but I can't pinpoint it...
Old Nov 28, 2011 | 11:03 PM
professor48's Avatar
Sometimes exhaust pipes have to be removed to change a rack. Were all the exhaust pipe connections re-tightened with the pipes in the same positions they were in before the rack was changed? Start the car and use your ear or a stethoscope to listen for noise sources. Check all the covers in the engine area, especially by the firewall. Was the steering column moved? If so, were its seals all replaced correctly? These are the things I would check. Hope this helps. Hy
Old Apr 26, 2012 | 02:09 PM
vr6vdub's Avatar
I found this thread while searching for something else but I have the exact same issue after having my power-steering rack replaced. I can hear valvetrain noise through the left HVAC vent. It's annoying the crap out of me.
Old Feb 23, 2013 | 12:43 PM
vr6vdub's Avatar
Any ideas? My car is at the dealership now for this noise I hear. They can't hear it. It's feint so I can't blame them but it's very noticeable to me.
Old Aug 25, 2022 | 10:05 AM
brianjrichter's Avatar
Bringing back a very old thread, what was the issue here? Having similiar issue after rack replacement on 07 TSX.
Thanks ALL!
Feb 25, 2020 09:57 AM
mike from annapolis
May 7, 2017 08:21 PM
Marmbo
4G TL Problems & Fixes
Sep 21, 2015 09:39 AM
iCrap
Sep 11, 2015 06:21 PM
