Engine makes squeaky noise
Old Dec 25, 2011 | 05:55 PM
darnnnel's Avatar
It has been getting a bit colder and all of a sudden i hear a squeaky noise, and it doesn't seem to go away even after normal operating temperature. I have included a video, any ideas?
Thanks!
Old Dec 28, 2011 | 12:22 PM
LoveMyTL-S's Avatar
Anyone?
Old Dec 28, 2011 | 01:10 PM
gwiffer's Avatar
Chirp from Timing Belt Area TSB...you'll have to search for it.
It requires the installation of a shim kit; how many miles are on your car?
It might be covered under warranty.
Old Dec 28, 2011 | 02:05 PM
swoosh's Avatar
takin care of Business in
I think it sounds like your power steering pump:
1> check if ther are any bubbles in the PS reservoir, if they are then replace your oring...
2> check the belt....make sure the belt is tight and not slipping
Here is the DIY to replacing the oring....remember to top off the fliud after you do the oring change:
https://acurazine.com/forums/3g-tl-problems-fixes-114/diy-105-power-steering-whine-fix-754586/
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
2012wagon
Sep 29, 2015 04:21 PM
iCrap
Sep 11, 2015 06:21 PM
Mike Bertram
Sep 10, 2015 09:27 AM
